Old 12-04-2017, 03:06 PM   #1
3azy_e215   3azy_e215 is offline
Doh! Need A FUEL TANK!!!!
So I have a 06 viva xv200s and my current gas tank is leaking. I've been Goodling for a while and can't seem to see one that looks to fit.
Does anyone know a bike that has the same style fuel tank???
Old 12-04-2017, 03:15 PM   #2
kirbo7106's Avatar
Gas tank
Can you post a picture of the current gas tank?
Dan-O
-2018 Tao Tao HellCat - DOA
Old 12-04-2017, 03:47 PM   #3
Here u go
Old 12-04-2017, 04:45 PM   #4
Take a picture of it without the seat installed so we can see how it is mounted. Maybe a few measurements. It looks similar to the Roketa DB-27-200
http://www.roketa.com/product/produc...D=0&proID=2037
2020 Kawasaki Vulcan S
Old 12-04-2017, 08:25 PM   #5
Adjuster's Avatar
Similar tanks all over Ebay. You just have to keep looking until you find the match or close enough you can modify to work. The tank is plastic, should be easy to repair???
Old 12-04-2017, 08:34 PM   #6
Mad
#2
Old 12-04-2017, 10:30 PM   #7
Angus67   Angus67 is offline
Angus67's Avatar
Mounting points look alot like my 06 roketa. Its steel btw
2006 roketa 200cc
1971 Yamaha xs650
2x 1980 xs650, 1 is a café, other is a chopper/brat
1972 Honda xl250
2x early 90's Honda rf600 parts bikes
more mc junk laying around.
Old 12-06-2017, 08:11 AM   #8
This is a possible fit. It shows dimension so you can compare. https://www.ebay.com/itm/New-ATV-Qua....c100005.m1851
Old 12-07-2017, 09:07 AM   #9
bogieboy's Avatar
i think i have one sitting in my parts pile.... where are you located?
Old 12-07-2017, 04:07 PM   #10
Im located in philly
Old 12-07-2017, 04:40 PM   #11
I can pay for shipping
Old 12-07-2017, 04:41 PM   #12
I was thinking the same but i feel as tho i couldnt use my plastics with that tank
Old 12-09-2017, 11:43 AM   #13
bogieboy's Avatar
i will pull it out this afternoon and send some pics... if i can remember that is...LOL
Old 12-18-2017, 01:58 PM   #14
There is way you can fix the tank you have if you haven't found one yet. It looks like that the leak is at the filler. If it is, one of my step daughter's quad had a similar leak. I was able to repair it with a soldering iron and plastic shavings from an oil container. I used the soldering iron to melt the broken sections together. I then took a wire wheel, chucked it into my drill, and created plastic shavings. I used an empty black, quart sized oil container that I first washed out and dried. I gathered up the shavings and dipped the iron into them to pick them up and melt them at the same time. I was able to use this process to fill in the areas where plastic was missing where the parts were joined. I did this repair last summer and it's held up so far.
Do a search for 'plastic welding with a soldering iron' and check out the videos. Some are showing just using iron while others are using some sort of plastic sticks.
Edit; just thought I would add, please, make sure that you empty and clean out the tank well before starting any repair.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 01-18-2018, 11:57 AM   #15
What ever happened, 3azy_e215? Did you replace or repair your tank?
