Old 06-17-2018, 11:23 AM   #1
DaveinOC   DaveinOC is offline
New CSC TT250
It's been at least a dozen years since I have ridden my last street bike, a Honda 250 Nighthawk (wish I'd never sold it!) and longer yet since my Husky was out. I just picked up my CSC TT250 last week and have just ridden a few miles.
I needed to crank up the shock preload and couldn't believe I had to pull the rear wheel to remove the airbox to get at the adjuster. A hat tip to 2LZ for the "trash can mod" idea. The new K&N style air filter doesn't seem to make any additional intake noise and with the side panel off the preload adjustment is now easy to make.
Despite my chagrin at having to half-dismantle the bike to crank up the preload I was impressed with all the fit and finish. All of the fasteners were perfect and the threads all were fine.
One thing that did surprise me was the combination of the rather tall seat height and the wide seat. Both of my Huskys are tall but have a narrow and rounded seat. The tall and wide TT250 seat is a bit more challenging to mount without standing on the pegs, but I'm going to wait a bit more before I decide on either lowering this seat or buying the CSC/Seat Concepts seat. (You don't think my lack of riding for 10 years and my increasing age are relevant do you, LOL)
I had a near mishap yesterday with a failure that I have never heard of before in over 50 years of motorcycle riding. I got on the bike after some shopping and kicked up the sidestand, went to take off and nearly crashed in the parking lot (yeah I know that sounds like a total newby, but wait) when the sidestand had redeployed itself. When I tried to get off the bike the stand collapsed and I nearly went down again.
Extricating myself I looked on the ground and there was the sidestand spring. I had either caught it with my boot or it had never been seated in the groove on one end. I didn't have the tool kit with me (THAT won't happen again) but managed to find a scrap bit of wire in the parking lot and tied the stand in the up position for the short ride home. I have installed a couple of c-clips on the outside of the spring grooves now, and I noticed that one end of the spring seems to have a shorter bent end than the other.
Anyone else ever hear of the sidestand spring falling off? I can't imagine what it would have caught on my boot to cause this...
1978 Husqvarna 250 WR
1991 Husqvarna WXE 250
2018 CSC TT250
Old 06-17-2018, 01:35 PM   #2
Essayons   Essayons is offline
Essayons's Avatar
Welcome Dave. My TT hasn't had that issue luckily but I will double check it just in case. Glad things didn't turn out worse.
Old 06-17-2018, 10:15 PM   #3
dpl096   dpl096 is offline
dpl096's Avatar
Thumbs Up
Welcome and congratulations on the bike. I believe you will find the bike a quality machine and the Seidner team top shelf folks.
― Thomas Jefferson
Old 06-17-2018, 10:46 PM   #4
Hawk 229cc   Hawk 229cc is offline
Hawk 229cc's Avatar
try taking the hump out of the seat is my plan i have a hawk an i need to sit near the back of the bike with my near 37in inseam leg room is a must
Old 06-17-2018, 11:03 PM   #5
Thanks Essayons i don't want to think too much about what kind of things could have happened on a left turn if that thing was loose! Hawk 229cc you have it exactly - what is that hump for? It seems so unnecessary I don't know what they were thinking but if I do cut down the seat that will definitely be smoothed out a lot.
2018 CSC TT250
Old 06-19-2018, 08:33 PM   #6
Well I had an experience that was kind of disappointing yesterday. I needed to go into my office, a little over 20 miles, and no freeways needed, so I thought it would be a chance to put a few miles on the bike. I made it to the office fine, varying the speed in mind of the new motor, and was on my way back when I got a flat front tire. I did not take Megdan's advice to replace the tubes 'cause hey this is CSC/Zongshen TT250, right? Well I would have been better off to take his advice.
The real bummer was waiting nearly 3 hours for the AAA to get there for the trailer ride home, and nowhere to take a leak!
Some other things became apparent:
  1. Always replace the stock tubes
  2. Make sure your cell phone has a good charge - mine was at 30% and I was sweating it out for a bit
  3. Have a USB charging port on the bike for the phone. I had a full battery charge and a functional engine but no way to get the two tied together.
Well lessons learned. The front tube clearly was pinched or folded over from the factory. I have two Tube Tuff Tubes on the way and should back riding by the weekend.
2018 CSC TT250
Old 06-19-2018, 08:42 PM   #7
wheelbender6's Avatar
Sorry about the flat. How is the power on the TT250 compared to the old Nighthawk twin?
Old 06-19-2018, 09:38 PM   #8
TT250 vs 250 Nighthawk
Using 10 year old impressions are that the power was about the same. Even though the Nighthawk is a twin it is not a very efficient engine. I never tried to take the Nighthawk on the freeway; probably a good plan. I remember commuting on the freeway on an Yamaha DT1 and I cringe now at my lane splitting youth! I am changing the standard rear 50 tooth sprocket with to a 45 when I fit the new rear tube.
2018 CSC TT250
Old 06-20-2018, 10:09 AM   #9
I've changed most tubes on my CB's but oddly enough, I've not changed the TT250 and have yet to have a mishap. I'm hoping they make it till the tires wear out, then I'll put in the Kenda Tuff Tubes that I've had great luck with.
Old 06-20-2018, 02:05 PM   #10
I often wonder if the stock tubes would last longer if the time was taken to unseat the tire bead and add some talcum powder. It wouldn't stop puncture damage issues or pinch flats, but may extend the life otherwise. My front also blew out on mine and when I pulled the tubes there was no evidence of any kind of powder inside the tire.
They are still cheap crappy tubes, but one would expect more life out of them than a few hundred miles.
Old 06-20-2018, 02:19 PM   #11
The pinched tube on my stock tube is what caused mine to blow. My tire had some kind of oil inside the tire. Stock tube would probably hold up but like you stated, from the get go you would need to unseat the tire bead and add some talcum powder.
2020 Kawasaki Vulcan S
Old 06-21-2018, 02:33 AM   #12
Essayons's Avatar
Is it possible to use tubeless tires with tubes. I've seen it done on a YouTube video. The video claimed that tubeless tires are tougher against punctures; and the tube would keep you from switching rims I guess.
Old 06-21-2018, 02:52 AM   #13
Yes, you can run tubeless tires with tubes. The general rule of thumb to go by is to reduce the speed rating of the tire by one grade when doing so. On my Goldwing I ran Shinko 230 Tourmasters which are Tubeless type tires with a V rating (149mph) but with a tube installed you would treat it as an H rated tire (130mph). This has to do with the fact that the inside of tube type tires are full of ridges and other textures that can rub through a tube. So it is always adviseable to use a generous amount of talcum powder inside the tire when installing it. This will reduce the friction between the tube and tire and prevent rub-through. I have run several thousand miles without a problem, so don't over think it too much.
Since these bikes struggle to reach much beyond 70mph on the best of days, it isn't as much of a concern.
Old 06-21-2018, 08:45 PM   #14
Cravin01   Cravin01 is offline
Cravin01's Avatar
welcome and sorry about starting thing out a little flat.
Visit me on YouTube at "Project Next"!
https://www.youtube.com/channel/UC6KTCi2GVbfRDv-2XCqHhsg?view_as=subscriber
2017 Bashan Storm
Keihen PZ30 Pumper Carb,115 main jet,35 pilot jet, gutted factory exhaust, Sambo Digital Speedometer,LED blinkers, H4 headlight,D.I.D X-ring chain 428,17/42 sprockets,UNI cone filter.
Old 06-24-2018, 08:57 PM   #15
Seat Improvement
Flat Seat Update:
I still feel like the seat is higher than necessary for a bike with 6" travel, but at least I was able to get rid of that maddening hump. Not sure if that is supposed to be for the never-gonna-happen passenger, especially since I removed their footpegs, but I was pleasantly surprised at how easy it was to do. Several things to note:
  1. The "turkey carver" electric knife works great on this seat foam
  2. DO NOT buy the current Harbor Freight "wide crown" stapler. It is being discontinued and they don't seem to be restocking the 7/16" wide staples any longer
  3. I was happy to pay $32 at Home Depot for an Arrow Pneumatic stapler vs. the being discontinued $25 HF one
  4. The Arrow takes regular T50 staples, which I have used forever in an electric one, so they will be available.
  5. The stock seat cover is really thin but stretchable and the seat looks like it is stock, just no more hump!
  6. The 1/4" long staples worked fine for the seat cover but I used 5/16" for the corners and the lacing
The Tuff Tube front tube is great; now to just get the rear (arriving Tuesday) and install the new sprocket. I checked on the prices and it was a better deal to get the CSC 47 rear with the new spacers and bolts so I can choose between that and the other JT 45 tooth I ordered on Amazon. I can use the CSC supplied $27 sprocket, bolts and spacers vs. paying about $15 for just bolts and spacers at the hardware store. I also figured it was cheaper to pay the $8.50 freight vs. about 3 gallons of gas in the truck to go pick it up lol.
2018 CSC TT250
