06-20-2019, 03:30 PM | #1 |
Hawk 250 won’t rev
Bought a hawk change to a vm26 carb put in a 115 main jet was running good. Got the aftermarket exhaust and pod air filter today installed both. And now can’t get engine to rev up. Low rpms seem fine. Adjusted the valves and moved up to the 125 main jet and add 2 washers to the needle didn’t seem to change anything. Would getting bigger pilot jets help?
06-20-2019, 03:31 PM | #2 |
Check that the choke is not on half way.
06-20-2019, 04:06 PM | #3 |
Good time to check the o-rings/seals on the carb and intake/engine flange (cheap Chinese o-rings like to shrink over time), air leaks between the engine and carb can cause some funny things to happen also
07-01-2019, 11:08 AM | #4 |
your new carb choke may be opposite of the oem
07-01-2019, 09:52 PM | #5 |
Remove pod filter as some block air flow!!
07-01-2019, 10:36 PM | #6 | |
07-01-2019, 11:05 PM | #7 |
Tuning the stock carb or mikuni or any other won’t work unless you understand things better
Kinda what I’ve said in the past n learning on the stock carb is a good starting point etc |
07-01-2019, 11:43 PM | #8 |
This. Very common mistake people make when installing the mikuni clones. Their chokes operate the.opposite of the stock carb.
Also, as Jerry said, if the choke is on half ir will be fine at low rpm/ throttle, but will be too restricted beyond that and... choke out.
