10-21-2019, 07:51 AM | #1 |
Looking for a quad now
I’m about to pull the trigger on a Tao Tao Rhino 250 I’m just hoping it’s got the same cult like following as my RPS Hawk. I see they share the same engine family. And I’ve watched every YouTube review I can find. What do you guys think of them are you happy with yours? Or would you have bought something else?
10-21-2019, 08:27 AM | #2 |
Like all Chinese bikes the Rhino has some quirks. The engines are bulletproof but things like ball joint rubbers, wheel bearings, etc., will need some attention. Its a simple machine and easy to work on. Mine has somewhere around 600 enjoyable hours on it so far. It's my main transportation when I'm boondocking in Arizona every winter.
10-21-2019, 09:01 AM | #3 |
I kinda figured wheel bearings were shipped kinda greased and any China rubber is half dry rot that’s the norm for these. I didn’t want the GY6 engine and belt transmission cause of all the hills and farm chore hauling. I think the clutch setup will last longer then the belt drive.
10-21-2019, 09:57 AM | #4 |
I know you said you wouldn't want the GY6 engine and belt drive but I would look into the Raptor 200 if you changed your mind.I bought the Bull 200 going on 3 months ago,I haven't pull anything with it yet,still trying to come up with a better tow hitch,but I don't believe it would have any trouble pulling stuff which is what I plan to do when I get a better hitch.I have a ball mounted on it right now.You will have to make some kind of hitch for the Rhino,it doesn't come with any mount at all.
10-21-2019, 10:16 AM | #5 |
I have been beating the hell out of my rhino. if I see water or mud I am in it just like a little kid again. the only issues I have had are I lost a bolt from the chain tensioner replacement cost $1.59. that's it after the carb swap and front sprocket swap it has been great.
I have been plowing, towing, mudding, hunting, ice fishing and trail riding with it so far. including a 100-mile poker run where I kept the throttle pinned for hours at 8000+ rpm and still runs great. I am not kidding throttle was pinned wide open for 1-1.5 hours at a time with only a 5 min cooldown in-between stops. I did that for 11 hours that day. |
10-21-2019, 06:03 PM | #6 |
Same here I beat the hell out of my Rhino...I tow some heavy loads up steep river banks (smaller front and larger rear sprocket)..... in, through, and out the creeks. I think you'll find it a very capable farm machine.
10-28-2019, 12:20 PM | #7 |
Well a Rino is on the way from Q9 powersports. They already called to confirm the order. Might be here by the weekend!! I post some pics when it lands. It’s the first new one for me, I’ve always had mid 80’s basket cases something clean will be nice for a change.
10-28-2019, 01:45 PM | #8 |
You have officially become a true Chinarider.
12-26-2019, 01:06 PM | #9 | |
2013 SSR XF-250 |
