06-16-2020, 07:51 AM | #16 |
About 65 (phone GPS) or 72 indicated. I have a 2020 TT250, and I have a 42 rear sprocket. I have rejetted. Funny I decided to rejet again on my 2nd oil change. I lost like 10 MPH up top. I backed out just about everything I had done (went from 112 to 117 main, needle from #3 to #4 and from 2 to 2.5 on the IMS, and then went back). One thing I should have realized would have cost me tons was a switch from 10w30 to 20w50. I changed that back out too. Now the bike is back to what I mentioned in my first sentence. Oh yea, the miss I had at WFO, got rid of that by replacing the "torch" plug with a proper NGK.
4 time WERA SuperVintage Roadracing National Champion, SCTA Land Speed Record Holder, 3rd AMA Motorcycle GP of Miami |
06-16-2020, 08:20 AM | #17 |
Top Speed: 68mph
Bike: Bashan Storm 250 Front/Rear Sprocket: 17/42 Mods: unifilter pod and outerwears cover, car customs exhaust. Carb Tuning: 118 main 38/40 pilot depending on temp Rider Weight: 225 lbs
2020 Triumph Tiger 900 rally. 2018 Bashan Storm 250. pz30b, digital cluster + gear indicator, unifilter and car customs full exhaust. 2019 Taotao 110b boulder atv. The "arm breaker" lol 2007 Honda VTX 1300R. 1974 Suzuki tm125, work in progress 2001 Suzuki Drz 400s. |
06-16-2020, 08:31 AM | #18 |
70mph on speedo
Bashan Motomax 250 17/46 NGK, stock exhaust and airbox 110 main, 1.5 turns 190 lbs 16' |
06-16-2020, 09:13 AM | #19 |
Top Speed Consistent 74-76 mph GPS (80 mph when the stars alien)
2016 Hawk 250 Keihin PE30 carb,125 main,32 slow. Pod filter Ported & decked head 10:1 CR Direct Ignition Coil 17/40 Sprockets, NGK DPR8EIX-9 Plug De-Cat Exhaust with Ebay muffler Dual Oil Cooler Rider weight 175 lbs Elevation Ground Zero.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 06-17-2020 at 08:08 AM. |
06-17-2020, 09:33 PM | #20 |
Bike: BMS CRP 250
Fakuni 30mm, 110 main, 25 pilot Top speed: 60 on the dash.. so probably 55. And I was pegged, full throttle, slightly downhill. Shortly thereafter, my whole rear wheel flew apart. Nobody died! Gonna go to a 40t on the rear soon.. let's see what happens! I think stock gearing is like 15/50 or something Last edited by 420chonda; 06-18-2020 at 08:57 PM. |
06-17-2020, 11:01 PM | #21 |
All Bashans are geared with 17/46 gearing.
06-18-2020, 12:04 PM | #22 |
Where's Azhule when ya need him! Didn't he set the Land Speed Record on his Bashan WILL? As I recall, there may have been a sonic boom when he did it.
06-18-2020, 09:06 PM | #24 |
I have a 42 on my storm and I don't think I would go any lower. Pretty noticeable loss of bottom end. You get used to it and it does knock the rpm down a lot on the top end.
06-18-2020, 09:17 PM | #25 |
68 mph Brozz gps measured (new carb and exhaust, stock gears)
59 mph Hawk gps measured (new carb, baffle removed, 17t front sprocket) |
06-18-2020, 11:18 PM | #26 |
Top Speed: 110 km/h GoPro GPS
Bike: Lifan 150cc Front/Rear Sprocket: 17/46 Mods: 65.5 piston, PWK 28, enhanced ignition coil, Custom cdi, rewired and improved stator. Iridium NGK plug Rider Weight: 180 |
06-19-2020, 05:30 AM | #27 |
85 to 90 kph with 15/45 gearing and 18 inch wheels.
Measured with GPS 125 ccm, 11 HP |
06-20-2020, 09:53 PM | #28 |
Do you think the 9mph difference is strictly due to gearing???
06-20-2020, 09:54 PM | #29 | |
Impressive for a 125cc! My first China bike was a crappy 125cc that peaked at about 45mph! |
06-21-2020, 08:08 AM | #30 |
Yes. And maybe exhaust as well.
mods, top speed |
