04-17-2023, 02:21 PM | #2 |
A pod filter is pretty common, and come in a few different styles, some require oil, some not. I am running the common Nibbi on both my Chinese enduro bikes. If you have a stock carb ,or VM26 clone you probably need a 42mm filter https://www.amazon.com/gp/aw/d/B09W2...b_b_asin_image
If you have a Nibbi PE28FL it takes a 48mm. If you do buy one measure to be sure. |
04-18-2023, 10:27 AM | #3 |
Thank you
04-20-2023, 12:10 PM | #4 |
So, I just got the Air Intake in. Sucks that you can't put the side panel back on because its in the way.
I think I'm going to remove the whole airbox. The hose that go from the airbox to the engine, can I just cut them so there short and leave them attached to the engine? I'm assuming it's just venting air for emissions. |
04-20-2023, 12:31 PM | #5 | |
04-20-2023, 01:25 PM | #6 |
If your bike is like a lot of these type bikes, then you will be making a mistake in removing the airbox, because it also serves as an inner fender, and most that do remove them have to put something in place to keep mud out.
04-20-2023, 01:41 PM | #7 |
I left the Airbox in place. With the angled filter everything will fit under the side cover with no mods to plastic.
04-20-2023, 03:04 PM | #8 |
Thanks all,
I'll mess around with it some more to see if I can get it to fit and put the plastic back on. Shawn |
04-20-2023, 06:51 PM | #10 |
TBR7 owner weighing in, I did a foam intake(https://mymotorcycleblog.com/tbr7-ha...d-replacement/) which was really big, then when I upgraded to a nibbi carb went with a cone filter( https://mymotorcycleblog.com/nibbi-c...allation-tbr7/ )
I like the cone since it's like my K&N's as far as cleaning and care. hth, |
05-05-2023, 07:58 AM | #11 |
If I were to do this air filter on my TT250, what is the benefit? I like how it looks, and the price can't be beat, and I'm always looking to do minor upgrades, but don't want to open a can of worms if it's unnecessary. The stock carb is still in there. I've got it in my amazon cart and thought I'd do a little more investigation before buying it.
