Old 12-30-2023, 10:29 PM   #1
GigaXi   GigaXi is offline
Templar 250X cracks on carb boot. Bonus question, Keihin PE carb vs stock carb.
Hi all! Quick question. Does anyone know a good replacement for the carb boot on the 250 templar X? Mine is all cracked. I don't think it's leaking air yet, but I have a feeling it's in my near future. Additionally, since I'll be taking the carb off to replace the boot, should I just replace the carb altogether? I've heard some good things about the stock carb, and some bad things. I'm not unhappy with it, but I have a brand new keihin carb just sitting in a box, collecting dust. Might as well switch, right?
Old 12-31-2023, 02:51 PM   #2
K'hermiit   K'hermiit is offline
K'hermiit's Avatar
There are Nibbi ones on Amazon for about 15 bucks. Probably what I will order when mine crack. If you have a good Keihin carb laying around of the right size...I would use it.
https://www.amazon.com/Motorcycle-Ma...s%2C199&sr=8-4
Old 12-31-2023, 05:20 PM   #3
Mikd   Mikd is offline
Mikd's Avatar
If you purchased it from powersportsmax I would contact them first about the cracked boot
Templar X
Vitacci Clash 200
Beta 300rr
GasGas TXT 125
Old 12-31-2023, 06:45 PM   #4
GypsyR   GypsyR is offline
GypsyR's Avatar
It keeps tickling my mind if a Keihin from/for like a Honda CRF 230 could be made to fit. Because I've always liked that little extra jump you get with an accelerator pump.
Old 12-31-2023, 07:58 PM   #5
Will this one fit?
Old 12-31-2023, 08:10 PM   #6
No, bought the bike used. Great condition, but it’s been sitting in a garage for about a year. I’m guessing why the boot cracked.
Old 12-31-2023, 09:49 PM   #7
I see replacement intake "Carb Intake Adapter Boot Rubber Pipe Flange"
WITH dimensions on ebay. There are many of them
My advise is remove it, take measurements. A micrometer, or just a ruler.
You will find one.
Old 01-01-2024, 09:16 AM   #8
K'hermiit's Avatar
Originally Posted by GigaXi View Post
Will this one fit?
That one is for a Honda crf 250, as Thumper suggested, measure the hole size and stud spacing on your old one to make sure, as there are multiple variations.
Old 01-01-2024, 10:21 AM   #9
Yes. Templar shares lots of parts with 20 year old Honda CRF 250. The front axel assembly, bearing and seals appear to be identical. When I start looking for parts, I usually try parts for that bike if I can't find Templar parts.
Old 01-01-2024, 07:03 PM   #10
Ahhh, was hoping someone knows the measurements. I was hoping to swap it out in one go. Thanks though, I'll measure it when I get to it.
Old 01-04-2024, 06:55 PM   #11
You were spot on!! Finally got around to taking off the boot and measuring it, and the link you shared is an exact fit! Engine side opening is 30mm, the bolt spacing is 61mm, and the carb side opening is 35mm. Thanks!
ID:	30606   Click image for larger version
ID:	30607   Click image for larger version
Old 01-04-2024, 07:00 PM   #12
Thought I'd tag you since I got around to measuring the boot. The amazon link K'hermiit shared was an exact fit and I have the boot measurements in the comment above. Just an FYI. Thanks!
Old 01-05-2024, 05:09 AM   #13
Thanks! This is definitely info for the Templar resource thread.
I had the thing off to seal it with orange permatex high temp since it had no gasket, and didn't think to measure it
Old 01-05-2024, 10:45 AM   #14
Perfect! Very happy to be a part of the giant templar knowledge thread haha
Old 01-05-2024, 02:51 PM   #15
bogieboy's Avatar
Fun fact.... those cracking intake boots can be fixed... i had the same thing on my Roketa DB07A when i got it back in 2012... i wrapped it with 4 layers of electrical tape anf never had an issue.... LOL
carb issues, carb upgrade, parts, templarx
