Old 12-28-2023, 03:58 PM   #1
skepticus   skepticus is offline
Kayo S200 carb upgrade recommendations
Hello Ladys and Gents,
I'm looking for a recommendation for a carb upgrade for a Kayo S200. It has a PZ30. I'm eyeing the NIBBI PE30.
Looking for recommendations the carb upgrade and a market place to source parts.
The stock carb is pretty much crap. Ran for 2 hours then went rich and bogs out. So something adjustable/tunable and rebuildable would be awesome!
Thanks!
Old 12-28-2023, 04:07 PM   #2
If going with the Nibbi, you will need to go with the PE28. The PE28 is a smooth bore so it will flow about the same as the PZ30.
2020 Kawasaki Vulcan S
Old 12-28-2023, 06:57 PM   #3
Thanks for the info. Pls excuse my ignorance but I just assumed the number was in reference to the mm size.
Old 12-28-2023, 07:38 PM   #4
XLsior   XLsior is offline
XLsior's Avatar
The PZ30 is a tapered bore with a choke plate so it basically its a restricted intake velocity.
The Nibbi being a smooth bore has less restriction which means greater air volume potential at a reduced velocity..
the issue being 200cc is not enough suck to make use of the PE30 smoothbore resulting in velocity drop and poor A/F tune.
the PE28 is still 'bigger' than the PZ30... even if the nominal exit hole diameter suggests otherwise.
at 300cc/20hp the PE30 starts to make sense.
Old 12-29-2023, 09:53 AM   #5
looking at 2 options now. any last minute suggestions/recommendations before i pull the trigger on one of these. pictures of the old carb and sxs below. actuall a "B PZ30". Thanks again!
https://www.amazon.com/JFG-RACING-Ca...1zcF9hdGY&th=1
https://www.amazon.com/dp/B0CBJB34FX...hlbWF0aWM&th=1
https://ibb.co/x5rSFsh
https://ibb.co/VCkfhYS
https://ibb.co/xM628MX
https://ibb.co/hyTRwSd
https://ibb.co/F6MZpvX
https://ibb.co/m0zdk0h
Old 12-29-2023, 10:27 AM   #6
I would go with the Nibbi PE28FL. It will perform better than the PZ30. https://amzn.to/3RIMvEU
Old 12-29-2023, 05:00 PM   #7
XLsior's Avatar
Aliexpress Nibbi official store...
https://www.aliexpress.com/item/1005...06788.html?spm
Old 01-19-2024, 02:42 PM   #8
Holding off any upgrades until it gets a new factory carb. Turned it back into the shop since it's still under warranty. Maybe there'll be more info out about which carb upgrade is best in a few months.
Old 05-20-2024, 11:43 AM   #9
thumpthump   thumpthump is offline
Hey there, do you have any updates on your Kayo S-200, and getting an upgraded carb for it?
I've got a family friend with one, and it's fun for his kids, but like most engines these days, it runs very lean, with all the issues that come along with that.
Thanks!
200cc, carb, kayo, s200
