Old 05-02-2024, 03:05 PM   #571
Originally Posted by cartel250cc View Post
Hey guys,
I recently purchased the Lifan KPX 250. While riding my clutch stopped engaging. I went ahead and took the cover off and noticed the top push rod was missing? I purchased a new one from CSC Motors for the TT250, It appeared to be the right part. However once putting the rod in my clutch cover will not close and the clutch cable is so tight im unable to adjust it at all. Im not sure if im doing the wrong repairs or not. I have a video showing the part and clutch plate issue.
Venom Motorsports hasnt been able to help me mutch. I would really love to get back up and riding again. Any advise?
That should be under warranty. Have to tried contacting American Lifan? I would reach out the Venom again. It's not like them to not take care of an issue right away.
2020 Kawasaki Vulcan S
Old 05-02-2024, 03:20 PM   #572
cartel250cc   cartel250cc is offline
Hey Jerry,
I am on the phone with them now. I followed the service guide you had listed and requested if they could find me a new top rod. but they have no really been helpful. Said they would get back to me but its been weeks now. Had the bike for less than 2 weeks and i cant ride it due to a top rod missing now.
its been really tough here in Georgia to even find a mechanic willing to look at the bike so im having to figure everything out by myself.
I love the bike, but repairs and guidance for it has been so tough. definitely disappointing.
Is it possible I could pay you for virtual advisement so i can outline the issue?
Old 05-02-2024, 03:45 PM   #573
Hey Jerry,
Which rod are you talking about? The rod in the center of the clutch? It has to be the correct rod to work like it supposed to.
My concern is where did the rod go to?
I'm sure Venom is probably trying to locate parts from American Lifan. Here's a link to the service manual that might help. https://drive.google.com/file/d/1C-W...usp=drive_link
Old 05-08-2024, 05:58 AM   #574
@jerryhawk yeah the top rod is what i need. i actually sent venom a photo of the service manual and they still can not find that piece. I went and purchased one from TT250 but it was too large.
I literally had the 250cc for 10 days. was riding one day and when i tried to throttle the gas the bike would not move. did some digging and took the clutch cover off. oiled up the plates so they werent sticking. thats when i noticed the top rod was not there? I am not sure if I lost upon reassembly or not. either or Venom hasnt been much help and no mechanics here in Georgia are willing to service chinese bikes due to getting the parts troubles?
needless to say my bike has been sitting now for almost a month. very frustrating to say the least
Old 05-08-2024, 06:49 AM   #575
PeanutRG   PeanutRG is offline
I'd be concerned about where the other rod went. If it was engaging before... something was there. You don't want to put it back together then have something worse happen...
Old 05-17-2024, 05:59 PM   #576
bigapple   bigapple is offline
Did VENOM or Lifan help you fix the issue with your motorcycle?
I'm seriously considering getting one, but hearing about your bike sitting for a month makes me think about opting for a used Japanese brand instead
Old 05-19-2024, 07:21 PM   #577
SlowMotion   SlowMotion is offline
After 2,800 miles, I replaced the stock chain with the RK Racing o-ring chain listed on kpx250.com. I lost 4 mph of top speed and my mpg has also decreased from all the drag of the o-ring chain. I had no idea it was that big of a drag.
Old 05-19-2024, 08:01 PM   #578
TominMO   TominMO is offline
Are you sure the chain isn't too tight?
2021 Lifan Xpect--sold
2022 Lifan KPX
1972 Honda CT90--The Carrot
1969 Honda CT90--The Tomahto
Old 05-20-2024, 11:28 AM   #579
Wow! Never heard of that! As mentioned, the tension and alignment of the wheels is right on???
Old 05-20-2024, 02:07 PM   #580
Regarding the two questions about the drag from the o-ring chain:
i thought it was this forum in which I read that there would be some drag with an o-ring chain compared to a non-o-ring chain, but maybe I am mistaken about which forum I read it on. In any case, I gather that it is well known that o-ring chains have more drag from the friction of the o-rings. I read that small displacement motocross racers will often use standard chains to avoid the slight performance decrease of o-ring chains. You can feel the stiffness in the o-ring chain right out of the package as you install it. It holds its shape, whereas the standard chain is as bendy as a wet noodle.
I can confirm that chain slack is spot on and wheels are as aligned as I can get them. The main reason that I got the o-ring chain was that the original chain seemed to wear/stretch faster than I would like so I was having to adjust the slack often. Rumor has it that the o-ring chain will wear slower and require less frequent slack adjustment. We will see!
Funny side effect: I have seen this on another motorcycle once. The KPX250 exhaust points right at the red side reflector on the license plate holder. The reflector plastic melted slightly over the course of 2,800 miles. When I put the o-ring chain on, it completely melted the reflector in less than 100 miles. I theorize this is because at highway speed with the o-ring chain, I am running WOT but getting lower RPMs. This combination somehow results in extra heat on the reflector. Maybe less cooling from a few mph lost with the o-ring chain.
Old 05-20-2024, 02:23 PM   #581
Yup. X-ring too. They just soak up power. The 172FMM engine in the KPR makes about 20 hp. My KTM motocross bike came with a standard chain, and it makes 50hp. No compromise.
I buy standard chains now (usually Takasago RK). They are much less expensive, but good chains. I want every bit of power these little engines can deliver! The cost savings with a standard chain may even outweight the more frequent replacement in the long run. If you are more than 50% highway, a standard chain should do. Riding in mud can do real damage. Keep it clean and lubed.
Old 05-21-2024, 01:13 PM   #582
IdahoRider   IdahoRider is offline
I have just over 10,000 miles on my KPX and I am using the same ORing chain I put on at 10 miles. I've only had to adjust the chain 4 or 5 times and I've gotten just over 80 mpg when I've checked my mileage in the past. I've never ridden the bike over about 60 mph so I have no idea it I've lost any top end speed I'll never use. My rear reflector started melting right away so they all came off in the first few miles after getting the bike
2022 Lifan KPX 250
Old 05-22-2024, 12:29 PM   #583
Does anyone else experience the same problem I am with gas leaking out of the seal between the gas tank and the gas cap? My gas cap just seems to not seal and the lowest part of the joint between the cap and the tank faces forward. It is always wet with gas there when I ride with a tank that is half full or more.
Old 05-22-2024, 01:12 PM   #584
No problem here. Are the screws tight? You might want to remove it and check the gasket.
Old 05-29-2024, 02:57 PM   #585
There is really nothing that I can see that would be adjustable, like a screw, that I could tighten to get a better seal on the gas cap. Venom arranged for me to receive a new gas cap. It leaks too, so now we suspect the tank is the problem.
