04-23-2017, 08:37 PM | #1 |
What model Baja Motorsports ATV is this???
No one has been able to identify this thing... hoping someone here can!
Older ATV made by Baja Motorsports. VIN comes up as a 2005. I did check their site, they don't list anything like this. Trying to find the model so I can locate at least a new petcock and a front right brake cable. Every part on it says NATIONAL MOTOR on it. The motor stamping behind the shifter is NM637259 The VIN on the frame is RKKGCKLCX5B637259 Any ideas? |
04-23-2017, 11:32 PM | #2 |
Road hard and put away wet. That thing is dangerous as is. Although that would never stop me.
04-24-2017, 06:14 AM | #3 |
Sure is! I rewired it and put that new coil on, she's a runner!
Of course, the idle climbs by itself, it has no brakes, no kill switch, and is sketchy as hell. All part of the challenge! Going to make it ridable with a end-of-the-world-mad-max sorta theme. |
04-24-2017, 07:25 AM | #4 |
Model: X150 https://hub.gardnerinc.com/customer_..._BREAKDOWN.pdf
RKK = Taiwan http://datagovtw.com/company.php?id=22003706 |http://xinglxm.diytrade.com/sdp/687897/3/home/0.html === Compare by the shape & measurement & find something that fits Typical petcock https://shop107992121.taobao.com/category-863472330.htm
04-24-2017, 11:51 AM | #6 |
04-24-2017, 04:17 PM | #7 |
http://www.jmcmotors.us/bajaparts/ma...IX%20RKKG).pdf
R. CRANKCOVER ASSEMBLY #12 had a oil filter ie. a Frankenstein that wants some Suzuki blood (16510-05240/ KN-131...) === Measurements of that Suzi: https://item.taobao.com/item.htm?id=530585143577
04-26-2017, 09:39 AM | #8 |
You're awesome, thanks for the link!
Now one last thing... where I might be able to find some of the less-universal parts. The exhaust studs are snapped off. I don't know if I can remove them or not. Odds of finding a jug are pretty much zero I'd imagine, right? |
04-26-2017, 05:07 PM | #9 | |
http://translate.baiducontent.com/tr...en=&monLang=zh | http://www.motorfans.com.cn/forum.ph...uthorid=290040
04-26-2017, 06:15 PM | #10 |
If you can get your hands on a mig welder, set a nut over the broken stud and weld the nut to the stud from the inside then unscrew it. Works nearly every time.
04-26-2017, 09:07 PM | #11 |
Use anti seize going back with replacements
I bet you could find the bolts at a place like Fastenal https://www.fastenal.com/ Or similar bolt speciality
04-26-2017, 10:57 PM | #12 |
It's either M6 https://item.taobao.com/item.htm?id=15023169968 (the pdf said M6*35) or M8 https://item.taobao.com/item.htm?id=42510987721 . Took it out as #11 said & measures it...
04-28-2017, 08:48 AM | #13 | |||
04-28-2017, 08:49 AM | #14 |
Do need a front left brake pull cable too. Bet you know right where to get one!
