06-24-2018, 01:20 AM | #136 | |
06-24-2018, 01:26 AM | #137 |
Grease? What's that?!
The following is photographic evidence of why I keep telling people it is worth going the extra step to remove the steering stem and greasing the steering head bearings.
Exhibit A: These pictures are the bearings as they were removed from my Hawk. The upper had at least some grease thinly smeared on most of the bearing surfaces, but the lower looks like somebody wiped a booger on it and called it good. Completely dry over 70-80% of either race and the ball bearings themselves. Upper: Lower:
06-24-2018, 01:33 AM | #138 |
This is after a Megadose of Megadan greasing.
I not only slathered the heck out of the bearings and races, but I smeared a bunch all over the inside of the neck as well, mostly to help ward off corrosion. Did I add a little too much, sure did. I just wiped away what squeezed past the seals. Upper: Lower: I did record a couple of videos of my work today. I managed to get a lot done, mostly tedious stuff, but the front suspension and steering is done as is most of my wiring. Once I get in the tach cluster in I can really finish it all up. Otherwise, I got the carb installed, intake/filter mostly figured out, and I just need to put the tank and panels back on then do the tubliss install and get the chain on.
06-24-2018, 02:10 AM | #139 |
Electrical work.
06-24-2018, 03:50 AM | #140 |
Steering and Fork servicing tips and tricks.
This is the guide from CSC on how to adjust the steering stem nut. My description wasn't the greatest I know. So, if you need a little more guidance, read here! https://www.cscmotorcycles.com/Articles.asp?ID=296
06-24-2018, 12:01 PM | #141 |
Something I did not mention in the fork video was that I did not get the YSS Valves installed. I did record a section on this and the reason why, but the audio on that clip was corrupted so I had to delete it. Long story short, the valves on their own will not seat into the damping rods. I have to make a pair of adapters in order for them to seat due to the shape of the top of the damping rod.
Once I make a pair at work I will turn around and install them again with their own separate video.
06-24-2018, 12:55 PM | #142 |
Good work on the stem bearings and forks. It's good to know the valves aren't a drop in. The lower stem bearing takes most of the weight of the bike and rider. The top acts as a brace to stop the forks from wanting to pivot back while traveling. If the bearings are overloaded with grease, they can slide along the race and flat spot. Do you see that being a problem with the hawk's open cage ball bearing design?
As crazy as it sounds, Honda skimps on grease on the CB500X which I own. They also use a similar ball bearing design in the stem. Mine have been needing replacement since not long after I bought my bike. Luckily, All Balls Racing has a roller bearing replacement kit. Anyway, manufactures claim the lack of grease is to prevent the balls from sliding and getting a flat spot. Which is what I think happened to my stem bearings. My bearing damage was from riding offroad with my bike loaded heavy, not from to much grease. I think the lower balls were beat enough to get flat spots. |
06-24-2018, 01:34 PM | #143 | |
I actually did a tapered roller bearing setup on my last Hawk from All Balls, and likely I will do it again with this one. For now, this works and will be more than fine.
06-24-2018, 07:19 PM | #144 |
what throttle is that? how long of a throttle cable did you use?
06-24-2018, 08:18 PM | #145 |
The throttle and cable came with the pumper carb I ordered off of aliexpress.
06-24-2018, 08:24 PM | #146 |
Made my adapters for the fork valves. Used the same broze bushings as my preload spacers but turned them down to exactly 23.8mm and gave them a quick hit with 320 emory. Tossed them in the mill and put a flat edge on the ends. This is essentially what Racetech sells as adapters, machined spacers.
You could easily do the same thing at home with the same size bushing and some sand paper, no fancy machines needed. It was just quicker this way. These are 15/16ths O.D. which is 23.8125mm
06-24-2018, 08:59 PM | #147 | |
06-24-2018, 10:37 PM | #148 | |
06-25-2018, 10:40 AM | #149 | |
Speaker magnet on the bottom of the triple will help keep them on the race if everything is steel. |
06-25-2018, 12:40 PM | #150 |
I used a magnetic tool tray, but it's a moot point now since I sold the Goldwing.
