06-18-2019, 03:11 PM | #1 |
Powersportsmax X-PRO Head
Need to see if this is the head we want
06-18-2019, 03:27 PM | #2 |
Looks like a CG head to me.
I wonder if it's a higher compression "performance" head or just a stock replacement.
06-18-2019, 04:00 PM | #3 |
Well it's the same head that JerryHawk250 bought and was discussing with Megadan about on another post but it never specifies if it was the right head it's just a stock replacement other than quench pad is round instead of hahaving squared off part near valves I was reading. But xpro has good reviews.
06-18-2019, 04:02 PM | #4 |
Also how do you put your signature at the bottom of every post like yours "If I had a doller for every women.......ect ect " do you just copy paste or I'm wondering???
06-18-2019, 04:14 PM | #5 | |
06-18-2019, 04:17 PM | #6 |
Nobody has used that head afaik. Most either buy a tt250 head, which is a much nicer casting, or use the stock head. The head I used was from ebay and the seller no longer has a listing for them.
06-18-2019, 04:17 PM | #7 |
Go to User CP in the upper left. You will see it in the menu.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 06-18-2019 at 05:00 PM. |
06-18-2019, 05:03 PM | #8 |
OK thanks alot and I'll let you guys know sorry for bugging
