03-02-2021, 11:46 PM | #1 |
New here and need help finding a specific sprocket
Hello all,
I purchased a 2020 Bashan Enforcer last fall. Absolutely love it. I'm in the process of the sprocket upgrade and am having issues finding the proper rear for a 428 pitch 45t. My sprocket is offset and I have only found one that is similar. The issue is mine is a 4 pin connector, theirs is 6. I was hoping someone here would know what I could do. This is the sprocket I could buy but has a 6 pin connection:https://www.ebay.com/itm/35326262729...m=353262627290 Any tips would be great. Thanks! Also, I've tried a standard sprocket. Does not line up with the front if it's not offset. Attached is a pic of my current sprocket. |
03-03-2021, 06:52 PM | #2 |
Welcome!!! I'm not really sure about if it fits your bike. If you look around for your factory sprocket, I'm sure you can find the original measurements. I will say this though... You've helped me find a possible sprocket for the KPM 200
03-03-2021, 07:21 PM | #3 |
Is there enough thread on the studs to use thick washers?
03-04-2021, 10:26 AM | #4 | |
Last edited by Falkon45; 03-10-2021 at 07:55 AM. Reason: Had to delete the sprocket link. It was incorrect |
parts |
