Old 11-22-2023, 07:44 AM   #1
MeZmeriZe   MeZmeriZe is offline
Grin 167fmm which valveguide is the bigger one.
Hi folks,
My 4 wheeler has a 167fmm pushrod motor and I decided to freshen it with new piston/rings and valves guides/valves and seals.
I managed to get the valve guides out without damaging the head, however I did mangle the old guides (I tapped them with a 6mm tap and then used a socket and a 6mm high tensile bolt to pull them out. I did damage the top and bottom of the old guides though by trying the press first.
Long story short, I have new guides to go in and one is half a centimeter longer than the other and I dont know if the longer one is intake or exhaust. Can anyone help?
Also has anyone taken out the base gasket and used liquid gasket instead for a small compression boost?
167fmm, valve guides
Search this Thread:
Advanced Search
Display Modes
