Old 11-27-2010, 01:50 AM   #91
I'm sure that you could easily swap the original CT stuff into the 125 engine, and then the entire original wiring harness would work. If you wanted to use a modern CDI stator in the 125, you'd be converting the system to 12 volt, and that would require new bulbs and a new battery.
Old 11-29-2010, 05:07 PM   #92
katoranger's Avatar
There is an adaptor available to mate the original wiring to the lifan stator. You can either convert to 12v or use a special 12v to 6v rectifier and retain all the stock bulbs.
Available at dratv.com
Since mine is missing all lights and wiring is ? I will just do the full conversion to 12v.
Old 11-29-2010, 05:22 PM   #93
katoranger's Avatar
Forgot to mention that I stripped the CT down the frame. Sorry no pics.
Concerned the the swingarm mounting area may be slightly tweaked.
Old 11-29-2010, 06:29 PM   #94
No photos! 8O Don't tease us, Allen!
Old 11-29-2010, 08:51 PM   #95
katoranger's Avatar
I had enough acorns to fill a coffee can from the inside of the frame. Appears the squirrels liked it.
Old 11-29-2010, 10:11 PM   #96
Those squirrels are going to be angry when they discover you took their acorns! 8O
Old 11-29-2010, 10:28 PM   #97
LOL! :P
Old 11-29-2010, 10:39 PM   #98
Is it un-tweakable?
Old 11-29-2010, 11:53 PM   #99
Git 'er done!
Untweaking device:
Old 11-30-2010, 02:13 AM   #100
Hopefully it doesn't come to that.
I've straightened lots of steel in the past with a large adjustable wrench (Crescent style) and a little heat. The benefit to the adjustable wrench is that it can tighten onto the piece and give you something to manipulate.
Old 11-30-2010, 02:15 AM   #101
Jim   Jim is offline
I don't know Derryk, Doc's untweaking device looks like more fun... Ok ok, at the cost of precision, but still... Doc, if I ever tweak my arm or some other limb or joint I hope I don't get the fun untweaking tools.
Hopefully you can straighten it out Allen.
"Be excellent to each other"
"We are all human. Let's start to prove it!"
Old 11-30-2010, 02:26 AM   #102
Seriously, I thought even the orthopedists only used the small hammer!
Old 11-30-2010, 09:30 AM   #103
katoranger's Avatar
I think I can fix it. The swingarm appears to be about a 1/4" off at the chain adjusters. So I may stick one of the three swingarms in there and attempt to tweak it back into place.
Old 11-30-2010, 11:11 AM   #104
The insurance only pays for the large untweaking device. 8O
I also use the adjustable wrench trick.It works well. I've not used heat also though.
Old 11-30-2010, 11:24 AM   #105
I find that cold steel is more likely to crack. Not a big deal when you have a MIG, but why not heat it and avoid the issue.
Search this Thread:
Advanced Search
Display Modes
