#61 |
Thank you for that reply. Yes, mainly cause of the rain.
#62 | |
PE28FL on SSR?
Hello, Do you or others know if this carb would fit the SSR XF250? |
#63 |
No idea if it would fit your bike. The XF250 is an entirely different machine.
#64 |
Has anybody solved the issue with the throttle cable butting into the gas tank with the PE28? My throttle cable is too short now and it won't rev all the way down, and revs even higher if i straighten the handlebars or turn to the right. Throttle cable adjustment is already as loose as it will allow.
Would this pressure against the gas tank be ok with the Nibbi throttle cable? Is there another throttle cable with a tight elbow off the top of the carb? Do I have to dent in the gas tank? Thanks! |
#65 | |
#66 | |
But, my stock intake hose has a kink in it. I think it hampers high rmp breathing. I just got an Uni foam pod filter and an 3" to 2" intake hose. I will try to incorporate protection from the airbox around Uni filter and hope the conical shape of the new intake tube lets her breath well at high RPM. I want to be able to take the highway for short spells if necessary. |
#67 | |
Howdy, long time since I posted, but I have been revamping my 2016 tt250 and installing a nibbi pe28FL, and just fought the exact same throttle cable battle you and Megadan were experiencing. I was able to reroute the stock cable in front of the forks and get it ALMOST perfect, but it still was just a hair too short and would stick open occasionally. I ended up buying this new cable from amazon as its the closest style I could find and had seemingly just the right amount of extra length. https://www.amazon.com/dp/B00X3JWENQ...roduct_details I got it today, and since the elbow/nut setup is slightly different than stock I did end up having to fabricate a small hold down bracket for the elbow - since the original hold down cannot be removed without cutting it, and wouldn't fit anyway since the elbow does not have that flare in it. JUST mocked up the prototype quick and dirty bracket, and this cable is PERFECT length for the PE28FL. I will add some pics tomorrow of my setup and hopefully will help someone. might remake the hold down now that I know exactly what I need, it was a bit of trial and error with a hammer to get the compound bend close.
2005 CBR600RR
2016 CSC TT250 Coming Soon |
#68 |
quick pics of the hold down I came up with for the new cable, vs the original. I will probably redo it to make it more precise but it does the job
hope to have everything re-assembled tonight, this carb sounds/runs great so far ![]() ![]() ![]() ![]()
2005 CBR600RR
#69 |
NIBBI 'Official Store" Aliexpress
NIBBI appears to be selling direct from Aliexpress...I linked bot the black and plain silver versions of the PE28FL.
You might have to shift click the links. https://www.aliexpress.com/item/1005...50663.html?spm https://www.aliexpress.com/item/1005...06788.html?spm |
#70 | |
Display Modes | |
