01-31-2018, 09:11 PM | #1 |
Front sprocket change
I have been reading about doing a front sprocket change to a 12tooth. Just wondering if I need to change both sprockets and chain or just do the front sprocket for now? Also has any one done this job before and how hard was it,?
Al |
01-31-2018, 09:35 PM | #2 |
What ATV are you talking about, and how many teeth does it have currently?
01-31-2018, 11:15 PM | #3 |
I changed from a 14 to a 12 and had no need to change the chain. Job was easy less than 10 minutes
02-01-2018, 10:24 AM | #4 |
If the current sprockets and chain have relatively few hours on them, I wouldn't hesitate to replace just the countershaft sprocket. With any luck, there is enough adjustment to take up the links. If not, cut one out.
02-01-2018, 10:01 PM | #5 |
2 teeth off of the front is the equivalent to adding 8 teeth to the rear.
You will get more low end torque and a little slower top end speeds. If you add a larger sprocket to the rear and a smaller sprocket to the front you will get even more torque. For the most part changing the front sprocket is easier then doing the rear. I asked what ATV this is being done on because some have CVT transmissions.. others have a manual clutch. The process of changing the front sprocket is different for each style but both are still easier then the rear. A chain breaker tool is a good one to have when removing links. Does a clean job of it. |
02-02-2018, 04:36 AM | #6 |
Thanks for the response. I am looking for a little more touque. Has some trouble pulling up hills. It is a auto trans with a wet clutch. After I get the sprocket changed out I going to try and put 2 inch spacers on the back tires for more stability
Display Modes | |
