06-20-2011, 08:01 AM | #1 |
rear brakes hanging up
Both my taotao 250-E atv's rear brakes drag at times, causing reduced speed and overly heated calipers. Any suggestions as to how to keep this from happening. Thanks
06-21-2011, 09:33 AM | #2 |
Wash mud from vehicle more often???? not saying you don't... but Mud will get on the caliper piston & cause it not to retract correctly while riding if it's full of mud.
Thanks, Bruce @ Endless Journey Cycles "Phone Calls Only" ~330-274-0098~ Hours: Tue.-Fri. 10:00-6:00 Sat. 10:00-4:00 EST. Dealer for: Lifan, Crossrunner ATVs. http://www.endlessjourneycycles.net |
06-21-2011, 08:54 PM | #3 |
Thanks for the suggestion.
06-21-2011, 09:20 PM | #4 |
brakes stick
if you have a foot brake pedal... look at the bolt that they use for a stopper... it maybe holding th epedal.. I had that on a GIO T3.. customer thought the calipher was sticky
06-22-2011, 12:49 AM | #5 |
Bleed the brake system out just in case it has picked up some air. when the air heats up it could cause the caliper to drag.
If it fixes it but reoccurs then remove the bleeder screw and lube the thread with some dialectric grease to seal the threads. I've seen this on a few china bikes and quads. |
06-22-2011, 07:33 AM | #6 |
Thanks every one, your assistance is greatly apreciated.[/b]
