Old 04-10-2016, 07:07 AM   #1
Photo Gallery: Show Us Your Zongshen RX3, and List Your Modifications
Show us your Zongshen RX3, and list the modifications you have made to personalize your bike. I recently repainted my RX3 in Patriotic Blue.
Here is the list of modifications to my RX3.
Custom Paint Job (Patriotic Blue)
Accessory Power Outlets
SpeedoDRD
55W/60 H4 Headlight Bulb
Trimmed Back of Headlight Housing to Dissipate Heat from H4 Bulb
Tusk D-Flex Handguards
Tusk 1-1/8" (30 mm Height) Handlebar Risers
Mobil1 Synthetic ATF Fork Oil
Tractor Supply Auxiliary Flood Lights
SuperBrightLEDs Auxiliary Spot Lights
Honda CRF250X Sintered Brake Pads for Front Brake
RAM Handlebar Mount for Garmin eTrex Legend GPS Receiver
Oxford Premium Touring Heated Grips
Grab On Foam Grip Covers
Modified Headlight Switch
Modified Fuel Gauge Sender to Flash Empty after using 2.9 Gallons of Fuel
Honda XR650L Folding Shift Lever
13T/46T Sprocket Combination
RK 520EXW Drive Chain
2nd Generation CSC Center Stand
CSC Progressive Shock Absorber
Garage Pro (JC Whitney) Travel Trunk
Relaced Rear Hub with Warp9 Rim, size 2.50-17
Installed Japanese Wheel Bearings in Rear Wheel Hub
Shinko 244 Rear Tire, size 4.60-17
Shinko 244 Front Tire, size 3.00-18
Old 04-10-2016, 08:54 AM   #2
Juanro   Juanro is offline
Juanro's Avatar
This is my bike. I purchased it new in September 2015. Approaching 16.000km.
I'm from Argentina, and here it's the carburated version, which comes with a rear 15' wheel
- Larger topcase, I commute to work and need to carry my notebook backpack.
- Winyoochanok windshield and handlebar risers.
- I just changed the rear rim to 215 x 17 in order to fit "standard" tires, shown with Metzeler Tourance 120/90/17 (already bought 185 x 19 front rim, will change soon)
- Aux LED lights.
- USB/12v over dashboard, both fed from independent line from battery with fuse and relay.
- Handlebar GPS mount.
- Handlebar end weights, also cut about 3cm each end, so current width including weights is the same as before.
- Mirrors from Honda NX400 (bigger and rectangular shape). Very sturdy, very little vibration even at "full speed".
- Front 15 tooth sprocket, rear standar 41.
- DID VX520H final chain (original worn out).
- Custom made centerstand.
- Front brake pads, origin Brazil, from Honda XR250.
- Bixenon headlight bulb.
- Small lens LED in place of the blue plastic cover inside headlight.
- Modified wire so dashboard lights up upon turning key on.
Old 04-10-2016, 11:48 AM   #3
AdventureDad   AdventureDad is offline
AdventureDad's Avatar
No pics of mine...all I have is an invoice Hey Spud, how do you like your Etrex GPS? I was torn between that an a 5" "car" gps from Garmin. With your Etrex, can you import routes, or make them with basecamp and export them from your PC to the Etrex, and being it's a small screen, can you see it well enough? Finally, does it do turn-by-turn navigation like a regular GPS?
Sorry to bombard you with questions, but you seem to have the mods I have on my DR, and or want on the RX3.
Old 04-10-2016, 11:53 AM   #4
Spud, looks good.
I don't see the csc badge, am I missing something?
Old 04-10-2016, 12:00 PM   #5
Yes, I can import and export tracks, routes, et cetera, from my eTrex Legend GPS receiver.
I bought the eTrex Legend primarily for dirt riding, because it is small and robust. I do use this GPS receiver while traveling on pavement. However, since the screen is small, I frequently need to pull off the road, and stop, to properly view the display. The eTrex Legend does give visual, turn-by-turn directions when approaching intersections. However, it does not give you an audio alert.
The eTrex Legend GPS receiver has been superseded by the eTrex 20X receiver.
https://buy.garmin.com/en-US/US/into...rod518046.html
Old 04-10-2016, 12:04 PM   #6
Spud, looks good.
Thank you, BB.
I have Zongshen roundels for my RX3. However, I am waiting for the paint to cure a bit more before I re-install them.
Old 04-10-2016, 12:39 PM   #7
Lee R   Lee R is offline
Lee R's Avatar
What brand paint did you use Spud? I'm tempted to plasti dip mine to a dark grey/green metallic. I'm not sure about the durability of the stuff though.
Old 04-10-2016, 01:02 PM   #8
Again, thank you.
Old 04-10-2016, 01:11 PM   #9
Green and Camo RX3
I couldn't upload the pics, but on Taobao, there is a green RX3 and a Camo version available. The green looks like the Triumph Tiger green. Very nice.
Old 04-10-2016, 02:15 PM   #10
dave92029   dave92029 is offline
https://flic.kr/p/A7gRDP
My mighty RX3 purchased June 25 with >5,500 Smiles
Tall Seat (Seat Concepts)
Center Stand (CSC)
Hand Guards (CSC)
Heated Grips (CSC)
10W Cree lights (CSC)
RAM mount (garmin)
Dave
Old 04-10-2016, 03:45 PM   #11
I painted both of my Zongshen motorcycles with Krylon Fusion spray paint.
http://www.krylon.com/products/fusion-for-plastic/
I then sprayed most of the parts with Krylon Fusion Clear Coat, which provides UV protection.
http://www.krylon.com/products/fusio...plastic-clear/
I painted the RX3 fuel tank and plastic 'wings' with SprayMax 2K Clear Coat, which is fuel and UV resistant. I wore a 95P respirator while spraying this product.
http://www.spraymax.com/index.php?id=361&L=1
Here are several photos of my Zongshen Sierra 200 (ZS200GY-2), showing the Patriotic Blue color in brighter light.
Old 04-10-2016, 11:40 PM   #12
rjmorel   rjmorel is offline
rjmorel's Avatar
Spud ,thanks for creating this photo gallery. It will be great to see all the mods and colors people come up with. How much overall speed you loose going from "fastest orange" to "Patriotic Blue" ? rj
Live Zong, and Prosper
Old 04-10-2016, 11:46 PM   #13
You're welcome, Rob. Thanks for making the excellent suggestion.
Much to my surprise, I discovered blue is as fast as orange. However, orange is still the fastest fading color. That's why I repainted my bike in Patriotic Blue, and sprayed UV resistant clear coat on all the plastic, and fuel resistant clear coat on the gas tank.
Old 04-11-2016, 01:17 AM   #14
Here is a comparison between my original, 2015 Orange RX3, and my new, Patriotic Blue RX3.
Old 04-12-2016, 04:02 PM   #15
rtking   rtking is offline
Sorry for the busy pic, but here's my farkles on my bike.
- Winyoochanok smoke windscreen
- CSC Auxiliary Outlets
- GPS handbar mount
- Tusk 30mm risers
- Cree LED H4 36W, 3200 lumen headlight bulb
- Trimmed back of headlight assemble for H4 incandescent cooling (good for H4 mod also)
- Auxiliary Lights: 2x4" 18W 6 Cree LED Spot Lamps
- CSC Big Brake Kit with Sintered Pads
- CSC Gen 2 Center Stand
- Akrapovic slip-on muffler and custom mid-pipe
- Header wrap (for larger diameter custom mid-pipe)
- 42 Tooth rear sprocket (for lower RPM highway cruising)
- Black reflective wheel stripes (better side visibility at night)
- Reflective tape on panniers and top case
