04-15-2016, 03:35 AM | #1 |
2006 Zongshen Sierra Intake problem and parts
Hey Everyone!
I just replaced my carb and my chike refuses to go off!!!!!!!1 Damn you choke and cable! Luckily our carb only has one cable so diagnosing is one cable less of a check! So upon inspection of the cable and the cable port on the carb found in the pictures in this link (http://chinariders.net/showthread.php?t=16079). So I sprayed some starter fluid on the carb while the choke was on (my mechanic said to do so) If it slows down then it's a manifold leak (to my knowledge this is how he helped me diagnose this. Luckily the TW200 is saving me from ordering from China and waiting a 3 weeks. Here is where I found a complete replacement boot, I actually bought from another local shop for $6 bucks less and will be in, in about 5 days! Let's hope she run's will update. Link for intake:http://www.yamahasportsplaza.com/oem...c7930b3/intake Have a great day! |
04-15-2016, 05:22 AM | #2 |
Did you order the carburetor joint, part #1? If so, I would also order the O-ring, part #2. After time, the O-ring will deteriorate, which allows air, and dirt, to enter the cylinder.
04-16-2016, 01:44 AM | #3 |
I bought the o-ring as well, the bracket was in good shape so I just found a new screw for the clamp. After that I should be rolling to campus in my Zong at last!I'll update when I get my parts.
