Old 11-06-2016, 09:44 AM   #16
When you wash your bike, you should remove the Shock Sox, and clean them separately. After the Shock Sox dry, you can re-install them on the fork tubes. Removing the Shock Sox requires you to remove the lower fork guards (chevrons).
Old 11-06-2016, 03:02 PM   #17
CSCDude   CSCDude is offline
CSCDude's Avatar
That looks good, Spud. Nicely done and a great report.
Joe
www.ExhaustNotes.us
Old 11-06-2016, 03:27 PM   #18
Jay In Milpitas's Avatar
Joe, can you confirm if the TT wheel will swap to the RX?
Old 11-06-2016, 11:20 PM   #19
The CSC tutorial for changing the front tire of the TT250 is located at the following link.
https://www.cscmotorcycles.com/Articles.asp?ID=292
Looking at the photographs, the front wheel of the TT250 appears to be the same as the front wheel of my Zongshen ZS200GY-2. If so, the brake rotor is different. Also, the right side of the hub, which connects to the speedometer drive gear, is also different.
Old 11-07-2016, 12:39 AM   #20
I would be remiss if I did not mention the CSC Cyclone RX3 has retained the original wheel geometry with the stock tires. CSC made certain the size 130/70-17, C6017 tire installed on the Cyclone RX3 was actually a little smaller in diameter than the original, 15-inch rear tire. Measuring the stock tires delivered with my CSC Cyclone RX3, I see the front tire is about 1-inch larger in diameter than the rear tire.
I introduced an imbalance in the wheel geometry when I installed a knobby tire with a more aggressive tread on the rear wheel of my RX3. In general, knobby tires are larger in diameter than the stock tires. For example, the size 5.10-17, Shinko, 244 rear tire has a diameter of 25.63 inches, as specified at the Shinko website.
http://www.shinkotireusa.com/tire/244-series
However, if you examine the Shinko 244 tires which will commonly be chosen for the 18-inch front wheel, they have the following diameters.
Shinko 244 Tires
Size 3.00-18 Tire: Diameter = 24.69 inches
Size 3.50-18 Tire: Diameter = 25.55 inches
Size 4.10-18 Tire: Diameter = 25.16 inches
All of these tires are actually smaller in diameter than the size 5.10-17, rear tire. In fact, the size 3.00-18 tire is almost one inch shorter. Given the knobby tires I prefer to mount, it's easy to introduce an imbalance in the original wheel geometry.
In contrast, here are the diameters of the tires I have currently mounted with the 21-inch front wheel.
Michelin T63 Rear Tire (Size 130/80-17): Diameter = 26.14 inches
https://www.denniskirk.com/michelin/...prd/643293.sku
Cheng Shin C858 Front Tire (Size 2.75-21): Diameter = 27.4 inches
http://www.csttires.com/int/moto/dual-spor/c858/
In this case, the front tire is approximately 1.25 inches larger in diameter than the rear tire, which allows me to re-establish the original wheel geometry supplied by Zongshen and CSC.
Based upon your tire preferences, and whether you have a 19-inch front wheel, you might not have any changes in wheel geometry. However, given my tire preferences, I can retain the original wheel geometry with a wider selection of tires after switching to the 21-inch front wheel.
Old 11-07-2016, 02:20 AM   #21
Thank you, Joe.
Old 11-08-2016, 02:41 PM   #22
I went for a ride yesterday on an unimproved road which can become a quagmire in the rainy season. I could not have completed this ride with the Shinko 244 tires. Here are some photographs from two muddy sections of the road.
Old 11-08-2016, 02:43 PM   #23
Old 11-08-2016, 02:46 PM   #24
After riding through the sloppy areas, these tires shed the mud very well.
Old 11-08-2016, 02:46 PM   #25
The Shock Sox do a good job keeping the fork tubes clean.
Old 11-08-2016, 02:48 PM   #26
Here a several photographs taken after I was heading home on the pavement.
Old 11-08-2016, 03:38 PM   #27
Merlin   Merlin is offline
Nice thanks for the pics. Makes me want to take a ride.
Old 11-08-2016, 04:49 PM   #28
Nice to see you in action, Spud!!! :-)
I hate that pasty type glue-mud. Every tire is a slick in one revolution.
Old 11-08-2016, 04:52 PM   #29
2LZ   2LZ is online now
Great to see your pics again Spud!...and wow.....those tires do seem to shed mud very quickly.
Old 11-08-2016, 06:19 PM   #30
Brave man, I think would been bypassing in the weeds. Looks like fun.
