Old 03-19-2017, 04:26 AM   #1
Biker_Andy   Biker_Andy is offline
Biker_Andy's Avatar
Chinese Dual Sports Comparison
Has anyone ever compiled a list of the differences between the many Chinese dual sports available? To be more specific the physical & licencing differences between the Brozz, Enforcer, Hawk, Magician, Stallion, Storm & TT250 along with any others bikes I missed. Some things I would like to know are:
Make?
Model?
Cost?
Engine Manufacturer?
Engine Size?
Counter Balanced?
Transmission?
USD Forks?
Wheel Sizes?
Kick-starter?
Electric Start?
Tire Type (knobby, dual or street)?
Brakes?
Adjustable Suspension?
Weight?
Seat Height?
Cargo Rack?
DOT Approved?
EPA Approved?
CARB Approved?
Old 03-19-2017, 10:58 AM   #2
Azhule   Azhule is offline
Added a few things to my list... hope you don't mind
Bashan "WILL" 200
(DB-03-R)
Cost of Bike? ~$1,400
Engine Manufacturer? Lifan (197cc engine / 164FML Lifan)
Transmission? 5 speed Manual
Counter Balanced? Yes
USD Forks? No
Wheel Sizes? 19" Front & 17" rear (90/90-19 & 110/90-17) (1.85x19 & 2.15x17)
Kick-starter? Yes
Electric Start? Yes
Tire Type? 80% Street Biased "Dual Sport" Tires
DOT Approved? Yes
CARB Approved? 49 State
Brakes? Front and Rear Disk Brakes, 2 piston calipers, regular/rubber brake hoses
Weight? Stock bike ~274 pounds / Modified bike ~255 pounds
Seat Height? ~30 inches
Rear Shock? Non-adjustable
Rear Carrier/Cargo Rack? No
Front / Rear Sprocket? 17t / 56t
Carb? "Keihin" PZ30 (not a real Keihin... decent copy... can't find Pilot Jet)
Spark Plug? "NGK" Copper (not a real NGK... not even a good copy)
Instrument Cluster? Analog, in Kilometers (off/slow over 15%), Neutral/Turn/Bright Lights Indicator Lights... No Tachometer, No Fuel Gauge, No Current Gear Indicator
Fuel Tank Size? ~2.1 gallons, no reserve on petcock... just "ON" or "OFF" settings
"Catalytic Converter"? Yes, 2 of them in the Header Pipe... 1 inside the "Egg" that is under the heat shield and 1 just before the Muffler/Mid Pipe
~~~~~~~ Aftermarket Stuff ~~~~~~~~~~~~~
Trail Tech Vapor? Yes ~$112 installed, Digital, in Miles (dead accurate for almost any rim/wheel size), Tachometer, Ambient Air and Engine Temperature Sensors
Carb? Yes ~$30, "Mikuni" VM26
Exhaust Header? No (due to frame design)
Exhaust Muffler? Yes ~$130, FMF Turbine Core II 1-1/4 inch
Rear Carrier/Cargo Rack? Possible...
Last edited by Azhule; 03-19-2017 at 04:12 PM. Reason: Edit to add stuff for 'BigWeld'
Old 03-19-2017, 12:35 PM   #3
Bashan Enforcer
Engine Manufacturer? No idea
Stock Carburetor: Kei Hin (Japan)
Counter Balanced? No
Stock Instrument Cluster? KPH, analog/dial type
USD Forks? No
Wheel Sizes? 21" Front and 18" rear
Stocker Sprocket: 17/46 teeth count (front/rear)
Kick-starter? Yes
Electric Start? Yes, with Remote Start Key Fob
Tire Type? Knobby, mostly Dirt
DOT Approved? Yes
CARB Approved? Yes, 49 State
[/B]Brakes? Front and Rear Disk Brakes, 1 piston caliper, regular/rubber brake hoses
Seat Height? 34 inches
Rear Shock? Non-adjustable, mono shock
Rear Carrier/Cargo Rack? No, but it has 4 bolts on rear fender where a rack could/should go
Stock Accessories? Comes with stock "Burrito" Tube.
Old 03-19-2017, 01:00 PM   #4
CARB is California's anal retentive one-state extra runaround that manufacturers have to go through in order to sell bikes in the state of California. The TT250 IS California CARB certified. So is SSR's XF 250. The rest of the 'usual suspects' of enduros are not.
Old 03-19-2017, 01:52 PM   #5
phager76   phager76 is offline
Bashan Blaze
Engine Manufacturer? Not sure, but I believe Lifan
USD Forks? No
Wheel Sizes? 18"/21"
Kick-starter? Yes
Electric Start? Yes
Tire Type? Off Road Biased "Dual Sport" Tires
DOT Approved? Yes
Brakes? Front and Rear Drum, regular/rubber brake hoses
Weight? Not sure, I believe just over 300lbs
Seat Height? ~33 inches
Rear Shock? Non-adjustable Mono shock
Rear Carrier/Cargo Rack? Yes
Hope you don't mind me cribbing the format from you Azhule!
Old 03-19-2017, 03:39 PM   #6
BigWeld   BigWeld is offline
BigWeld's Avatar
I can see this thread becoming a Sticky. Great idea! I'll add some Brozz info unless someone beats me to it. Also, if the previous posters don't mind adding some info, I think it's a good idea to add the stock gear sizes, analog/digital gauge cluster, and which carburetor the bike comes factory equipped with, in each listing. These are areas that most people mod and could be a deciding factor when purchasing a bike.
(Initial cost vs the cost of the mods)
Old 03-20-2017, 05:09 AM   #7
Biker_Andy's Avatar
Once all the raw data is here in one place I was planning on putting it all together in a spreadsheet and then saving it and posting it as a jpeg for easy viewing. I agree that once it is completed it should be a sticky. It will make it a lot easier for people to decide on which bike for what purpose. Thanks for all the help so far!
Old 03-20-2017, 06:31 AM   #8
I updated mine with additional info. Not sure why it's automatically hyperlinking the words Instrument Cluster and sending you to ebay when you click on it. I didn't set that up. Actually, I deleted it and retyped it and it automatically does this.
Old 03-20-2017, 06:57 AM   #9
Rail32   Rail32 is offline
Rail32's Avatar
O
Hawk 250
USD Forks? NO
Wheel Sizes? 21" Front & 18" Rear
Kick-starter? Yes
Electric Start? Yes
Tire Type? Knobbie
DOT Approved? No
CARB Approved ? No
Living life to the fullest to avoid regrets later ,,,,or I am a complete loon ! Either way I am good
Old 03-20-2017, 09:44 AM   #10
Merlin   Merlin is offline
The hawk is not CARB or DOT approved just EPA.
Bashan Blaze
Mods: Alloy Rim's, Muffler, Mukuni VM26 Carb, Foam Filter, Tachometer, Volt Meter,LED Headlight, LED Blinkers
Old 03-20-2017, 11:30 AM   #11
SSR XF250
http://www.ssrmotorsports.com/store/enduro/xf250.php
Engine Manufacturer? QingQi
Displacement: 249cc OHC
USD Forks? Yes with dampening adjustment.
Wheel Sizes?
18 front 17 rear- dual sport tires (dual sport)
17 front 17 rear- street tires (supermoto)
Kick-starter? Yes
Electric Start? Yes
Tire Type? see above
DOT Approved? Yes
CARB Approved? Yes - 50 state approval
Brakes? Front and Rear disk, braided lines
Weight? 328 lbs
Seat Height? 35 inches
Rear Shock? Gas mono shock
Old 03-20-2017, 08:38 PM   #12
Rail32's Avatar
Noted and changed .
But how can it be lice sensed if not DOT approved , just asking ?
Old 03-20-2017, 08:43 PM   #13
Originally Posted by Rail32 View Post
Noted and changed .
That is the problem with the Hawk hit and miss when it comes to getting it plated.
Bashan Blaze
Old 03-20-2017, 11:12 PM   #14
pistolclass's Avatar
Noted and changed .
Licensing is up to each state. If your state only requires certain number of street items (lights, blinkers, cup holders.... whatever) then they can plate it. In CT it is hit or miss with the Hawk. That is why i went the VT route. Give VT about $120 and they give you a plate. Then I will transfer it when the plate expires in November. If CT give me trouble I will register it NH where I have some vacation property.
If CT does not want my money I will gladly give it to a state that does.
Old 03-20-2017, 11:19 PM   #15
mjs91882   mjs91882 is offline
Brozz
