04-02-2017, 02:24 PM | #541 | |
04-04-2017, 05:07 PM | #542 |
Ariel Owners Guide
On running in (also called breaking in). There are people who don't believe in running in an engine, transmission, or brakes. But I do. And so, for those who agree, let me quote Ariels little book. "Proper running in of the new engine is of the utmost importance, as misuse during the first few hundred miles will (today we can say may) lead to poor results, and unnecessary expense. Definite running-in speeds cannot be given, as the safe limit of speed absolutely depends on road conditions, etc. Keep the engine turning over easily on small throttle openings, letting it rev, rather than pull slowly on large throttle openings. All motor cycles leaving Selly Oak are in first class condition, but we have to leave the running-in to you. What your engine ultimately becomes depends on YOUR care during the first 500-1000 miles (on a Hawk the 500 mile mark means the engine is broken in). Give yourself lasting satisfaction by using restraint until the piston and cylinder have become seasoned by constant heating and cooling and have acquired first class bearing surfaces and well-fitting rings. During the first few hundred miles running, check all nuts, bolts, screws and spoke nipples, etc, for tightness as parts will bed down during the running-in period thus causing slack bolts, etc. An upper cylinder lubricant (such as Marvel Mystery Oil) added to the fuel will assist valve lubrication and may be used throughout the life of the engine.
It is advisable to change the oil at the 200 mile mark and at 500 miles (for the Hawk) in order to remove any traces of metallic particles and foreign matter which may be liberated during the running-in process"...ARH Last edited by Ariel Red Hunter; 04-04-2017 at 05:10 PM. Reason: remove excess verbiage |
04-05-2017, 11:15 AM | #543 |
Oil Changes
In my post of yesterday, I mentioned oil changes at 200 and 500 miles. That was what the Ariel works recommended. But they were shipping out their bikes with the best lubricating oils of the day. They also ran in Red Hunter engines for four hours each on the bench, running a fan to absorb some of the horsepower. But the Hawk comes with anti-rust oil in the crank case and transmission, not high quality lubricating oil. So, it is up to YOU to change out the oil before riding the machine very much. I do think that running the engine for a few moments in order to thin out the oil before dumping it is a good idea...ARH
04-06-2017, 12:58 PM | #544 |
Dear Ariel Red Hunter, just want to thank you for sharing with us the wealth of your knowledge and experience. I catch myself a number of times returning to your comments thinking "What ARH says about this and that?" Finally I've collected almost all of your comments from this thread into one single file (slightly rearranged). It could be downloaded from here -
http://www.mediafire.com/file/l4udsz...pr+5+20127.doc I named it "ARH Wisdom book". This file will be updated on a regular basis as well. Thank you for being with us. |
04-07-2017, 02:04 PM | #545 | |
04-07-2017, 02:30 PM | #546 | |
04-07-2017, 02:35 PM | #547 |
Now I need a favor.
The favor is: I need one of you computer genius's to find a way to add an avatar to my signature page. The avatar I want is the art-deco stylised horses head that was the Ariel signature (emblem). Can one of you do this for me? And then I would like to bore you with the bike I've really wanted, but could never get. The triangular framed Cotton with a 350 or 500 J.A.P. engine, and a Burman foot shift transmission. Cotton was a very small motorcycle manufacturer who were famous for this frame. Did well at the TT in the twenties, which is why the two t's in the name are capitalized. Any way, those "80 Bore" J.A.Ps are fascinating to me. James A Prestwich was who the engines were named for, not the island of Japan, by the way. You can google up "CoTTon Motor Cycles" to see what one looked like. Most of the type I'm talking about were made before WW 2. These engines were famous for pulling power, and never since has so little oil circulated to so few parts, and stayed together. And stayed together with enthusiasm I might add. Stock they were 80 mph motor cycles, but, like all overhead J.A.P.'s, could be tuned to well over 90, and some reached 100-110. On one of the strangest oiling systems ever. I will recite the technique of oiling, maybe tomorrow....ARH
04-07-2017, 05:29 PM | #548 | |
Do you have an image? Is my avatar what you wanted? |
04-07-2017, 06:36 PM | #549 |
That's actually the North American Ariel Owners Club badge, but since I'm a member, it will do fine. Thank you. Now how do we get it on my page?
04-07-2017, 06:43 PM | #550 |
PM sent
04-07-2017, 06:49 PM | #551 |
Rather attractive in an old fashioned machine age style, don't you think?
04-07-2017, 06:52 PM | #552 |
I liked it but it is special to you so I removed it from my profile and avatar
2016 Brozz |
04-07-2017, 07:50 PM | #553 |
You shouldn't have done that. Having two Ariel lovers on here is better than only one. Although the horse is only used for the red hunter, because, in England they wear red and ride a type of horse called a hunter, when they are out annoying the foxes....ARH
04-07-2017, 08:00 PM | #554 | |
2016 Brozz |
04-08-2017, 03:16 AM | #555 | |
I'm a new Hawk owner (just left TX on a brown truck), but have been lurking a few weeks. I also have the mikuni knockoff and jets coming, and will be performing surgery on the header pipe and air box right off the bat. |
