Old 04-10-2017, 01:15 PM   #16
Ariel Red Hunter's Avatar
Originally Posted by Merlin View Post
Still sounds like a vacuum like to me so before I disassemble my bike again Ill check for leaks. My mind says vacuum leak but my intuition says valves.
I just put a little snippet on Hawk Talk about adjusting valves. I hope it helps you. I agree with your statement. I too would make sure the valve clearances were spot on, then, if that doesn't resolve the problem - explore further....ARH
Old 04-10-2017, 01:22 PM   #17
Merlin   Merlin is offline
Originally Posted by goat67 View Post
Where would you have a vacuum leak?
Did you remove the carb?
Do you have the smog stuff still on that would be the only place that any vacuum would be produced.
There is a vacuum takeoff on the intake manifold. I still have the smog thing coming off the side if the cylinder. I have it plugged. The carb itself. Ill check all these spots before I have to more or less remove my engine so I can get to the valves again. You guys have it easy with the blaze you have to drop the engine to get to the valves and there is a lot more to it then it sounds.
Bashan Blaze
Mods: Alloy Rim's, Muffler, Mukuni VM26 Carb, Foam Filter, Tachometer, Volt Meter,LED Headlight, LED Blinkers
Old 04-10-2017, 04:51 PM   #18
Ok here's an update:
Vacuum is not the problem. Valves not the problem. As I was taking the bike apart I was checking everything I had touched and lo and behold I found a spark plug with almost NO gap?! (what a sap) After giving it the right gap the bike seems to be running better then ever. It doesn't take as long to warn up and it idles better. Iam going to take a trip to the top of the world and check it out.
Bashan Blaze
Old 04-10-2017, 04:53 PM   #19
Kipper1012   Kipper1012 is offline
Kipper1012's Avatar
Stock plug?
2016 Green Bashan Brozz.
Old 04-10-2017, 04:58 PM   #20
Stock dropped NGK plug. I must of dropped this plug when I was working on the valves. Glad I always look at the easiest fix first. Now the bike has that sewing machine sound I've read about.
Bashan Blaze
Old 04-10-2017, 06:12 PM   #21
Kipper1012's Avatar
good to hear !
Old 04-10-2017, 06:17 PM   #22
goat67   goat67 is offline
goat67's Avatar
Glad you figured it out. KISS a motto to live by.
2016 Brozz
Old 04-11-2017, 09:37 AM   #23
Sullybiker   Sullybiker is offline
Sullybiker's Avatar
I hope you mean one decimal place over, right?
