05-23-2018, 12:06 AM | #1 |
Tao Tao ATA 150 G wiring diagram
Would anyone happen to have a wiring diagram for a 150G? I picked one up cheap today and it runs but needs some wiring diagnostics as you have to jump it off the starter for now. Also, where would you good folk recommend I get a complete caliper/master cylinder set from. Amazon seems to have a Goolsomething set I can get or should I just get it from partskit?
I am resurrecting this thing from neglect! 😀 |
05-23-2018, 08:00 AM | #2 |
Check the brake light switches and wiring. They also function as safety switches. Starter will not work if they are not functioning properly. This is for a Coolster 3150DX-2 but wiring should be close to the same.
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 05-23-2018 at 09:01 AM. |
05-23-2018, 06:31 PM | #3 |
Dang! Where can I get a carburetor greaser?
(It's about in the middle, towards the bottom).
05-23-2018, 08:53 PM | #4 |
Any GY6 scooter http://do.ejdz.cn:8087/%E6%91%A9%E6%...F%E5%9B%BE.gif wiring diagram is useful...
05-24-2018, 08:27 AM | #5 | |
05-24-2018, 08:39 AM | #6 |
If the brake lights are not working that indicates the that the safety switch will not be working either. So it will not start.
