Old 11-27-2018, 02:07 PM   #1
cycle   cycle is offline
rhino 250 Winch and mounting plate...
greetings folks.
new member here. I just purchased my rhino and will be installing modifications that I have read about on the site. I will be installing a winch so I am looking for what brands you folks have installed and what brackets are needed to install on the rhino. didn't see what I needed doing a search so I thought I'd post my first question.
oh and please reply where you purchased.
thanks
Old 11-29-2018, 05:45 PM   #2
Darth Racer's Avatar
I used the Harbor Freight atv winch https://www.harborfreight.com/2500-l...rol-61297.html
Later added a synthetic rope line after I found out cable sucks when it gets a little frayed and a little wire stabs your hand.. https://www.harborfreight.com/atvutv...kit-63139.html
The included fairlead wont allow you to suck in the hook like the stock one does. When it happens it sucks too.
I made a rubber anti suck puck out of a cheap rubber mallet .... works well.
For brackets I used what came with the winch and some angle iron to bolt it to the frame in multiple points to not put too much stress in just one spot.
Old 11-29-2018, 05:53 PM   #3
I remember that. Sucked mine back in too and had to mostly disassemble the dang thing to retrieve it. I bought the rubber puck but I liked your cheap rubber mallet idea better!
Old 11-30-2018, 11:25 PM   #4
thanks for the replies..much appreciated!
Old 12-02-2018, 08:59 PM   #5
PANDEMIC   PANDEMIC is offline
This is how i did my harbor freight winch with winch mounting plate also purchased from harbor freight. I made additional mounting plates to sandwich the taotao frame. starts on the 9th picture down hope this helps.
http://chinariders.net/showthread.php?t=20909
Old 12-06-2018, 02:31 PM   #6
I does...and thanks
Old 12-09-2018, 12:56 PM   #7
in hindsight, I wish I would have made my sandwich plates a little longer so I could have added another bolt on the outside of the taotao frame also.
Old 12-09-2018, 02:39 PM   #8
I noticed that and made mine a tad longer so the bolts on the right side are outside the frame.
Old 12-09-2018, 03:31 PM   #9
so did you get it all together?
Old 12-09-2018, 05:02 PM   #10
yes..everything is installed..still have to paint the brackets tho...too cold here to do it now.
Old 12-09-2018, 05:33 PM   #11
where are you located? I am here in Milwaukee, WI
Old 12-09-2018, 05:46 PM   #12
Memphis, Tn
Old 05-01-2021, 11:12 PM   #13
Khendricks1129   Khendricks1129 is offline
Can you post pictures? I followed the link to your thread where you posted pictures but the links are no good. I would love to see how you did it.
Old 05-02-2021, 09:03 PM   #14
There are a couple of winch mount mods on my thread.... mine as well.
http://www.chinariders.net/showthrea...t=16553&page=2
