Old 01-18-2019, 05:31 PM   #16
Biker_Andy   Biker_Andy is offline
Biker_Andy's Avatar
I bought some LED lights from China that say if the light flickers to call them an order a "flux capacitor". Sadly I have no interest in turning my motorcycle into a time machine.
Do you notice any flickering on other lights or just the headlight? Does the flickering go away if you stop moving or only when the engine is off & key is on?
If other lights flicker it could be a slopy ground, poor battery connection or bad battery (bad drop & broken inside)
If other lights flicker and it only goes away when the engine is off that's a good indication of a "noisy" electrical system which can be fixed with a capacitor.
If it's only the headlight and only when moving its got electrical connection written all over it. Maybe inside the bulb, maybe the connector or maybe further down the harness.
If it flickers when the engine isn't running then you have a faulty LED light.
Electrician & Electronics Tech
2014 Honda CB500XA
2016 CSC TT250
1976 Honda CJ360T
2022 Honda Navi
Old 01-18-2019, 07:03 PM   #17
chuck   chuck is offline
Originally Posted by RKG83 View Post
Also another quick question. Anyone have issues with the stock headlight flickering a lot? I took the bike into the dealer and they found no wiring issues, could it be a cheap bulb issue?
The alternator on our bikes (Icebear little monster) is not that powerful,you will notice that once the engine warms up and in higher rev's it is brighter and stable.
Old 01-18-2019, 09:28 PM   #18
glavey   glavey is offline
I have heard that the little LEDs on the stock bulbs commonly have poor solder joints, causing flickering especially when vibration is added. One of the LEDs on my low beam light is starting to go out, but I've only ridden it about 500 miles.
Old 01-18-2019, 10:07 PM   #19
Whisky   Whisky is offline
Whisky's Avatar
The LED lights that came with my bike sucked
Bad. That was one of the first thing I replaced.
2018 BD125-8-x21rs
ZS190/Genuine PE28
Kepspeed GP1 Exhaust
Protaper se x110 bars/grips
1/4 MotionPro throttle
Kepspeed Braced swingarm
Chimera rear hub assy
Grom Intergrated tail light
Superlite Sprockets 17/32
custom made from Japan
Chimera Swing Arm Bolt
RK MXZ Chain #420
All Balls wheel bearings
Motodynamic fender eliminator
Coremoto ss brake lines
Composimo 2.5 lower link
Grom Calipers-w/ebc pads/rotors
Michelin tire 140&120
13x4/13x7 fatties
Grom forks
Old 01-23-2019, 05:04 AM   #20
RKG83   RKG83 is offline
https://www.ebay.com/itm/Tail-Tidy-L...2320%7Ciid%3A1
Will this fit on the Vader? I found one on Amazon for $90, this one is much cheaper comes with and LED light.. just skeptical
Old 01-25-2019, 11:12 AM   #21
loak1ere   loak1ere is offline
loak1ere's Avatar
has anyone ever tried a mikuni flat slide carb on these bikes? I've looked for info but haven't found any on flat slides.
Old 01-25-2019, 09:23 PM   #22
wlfpck   wlfpck is offline
You can fit whatever carb you want as long as you can physically fit it on and your throttle cable will work with it. Reason everyone goes with the VM22-133 is because the manifold and carb is all tired and tested. Not to mention is all bolts together without clamps.
If it fits the grom, it should fit the vader grom clone. There are cheaper ones on amazon and ebay that work.
2020 Honda Grom
2017 Icebear Fuerza (Daix PMZ125-1) - Sold
Old 01-29-2019, 12:34 PM   #23
cbrfxr67   cbrfxr67 is offline
cbrfxr67's Avatar
I went with a molkt carb because it had the adjustment knob and the pull choke. I was unsure at first but it's been kick a@@ over the mikuni I tried first.
BD125-15
