Fender Eliminator
Vagabond Motorsports Honda Grom (2017+) VM-HG710 Fender Eliminator https://www.amazon.com/dp/B01M0VTHCF..._vfJzCbNKDGVTF
Will this fit a 2018 Boom? The fender on the boom looks exactly like the Groms so I’m assuming it would fit. Anyone have any experience with these? |
Does yours have the Gen2 bodywork ? ( looks just like the Gen2 Grom ) the reason I ask is ,Venom still sells the "original" style bodywork/plastics model even though it is listed as a 2018 ,it has the plastics style from the original 2014/15 Grom .
I dont have experience with that particular tail tidy but i can tell you that i used a 2018 Grom part on my 2018 Gen2 Vader and it went right on there , no muss no fuss perfect fit, so i assume that one would go right on there as well .If yours has the "OG" style body work then I can't say if it will fit or not you might need one for a 2015 style Grom.
#3 | |
Steady Garage has one for a ssr Raskull for 54. Bucks.
Check it out. My bike is a clone of the Raskull, looks like a Ducatti Monster. Should fit no problem.
2018 BD125-8-x21rs ZS190/Genuine PE28 Kepspeed GP1 Exhaust Protaper se x110 bars/grips 1/4 MotionPro throttle Kepspeed Braced swingarm Chimera rear hub assy Grom Intergrated tail light Superlite Sprockets 17/32 custom made from Japan Chimera Swing Arm Bolt RK MXZ Chain #420 All Balls wheel bearings Motodynamic fender eliminator Coremoto ss brake lines Composimo 2.5 lower link Grom Calipers-w/ebc pads/rotors Michelin tire 140&120 13x4/13x7 fatties Grom forks |
Would like to see some more pictures of your bike. Looks beefy.
