Old 07-24-2019, 12:22 PM   #1
autowerks123   autowerks123 is offline
key fob does not work. reprogram?
how do you reprogram the key fob on a tao atv?
Old 07-24-2019, 04:08 PM   #2
Have you checked the battery? I had one that would work when it felt like it. Turned out the battery came loose from the hot glue that held it in place. Re-glued it in place and was good to go.
2020 Kawasaki Vulcan S
Old 07-28-2019, 01:15 PM   #3
battery for fob
I see the battery is a 12 volt battery on these.... yes I would like to know how to re-program them as well... I guess check youtube for this..
ABIBABA ATV ETC
Old 07-29-2019, 04:45 AM   #4
humanbeing's Avatar
Originally Posted by FLASHLIGHTBOY View Post
... I would like to know how to re-program them as well... I guess check youtube for this..
There's a "reset" (most are covered by a rubber plug some need take it apart ) in the alarm unit.
More or less the same as
https://fccid.io/Q6W986/User-Manual/users-manual-360911
Find something machine translate it
https://drive.google.com/file/d/1GJd...ew?usp=sharing https://zhidao.baidu.com/question/100777121.html
