Old 02-20-2020, 12:27 PM   #31
imapdog   imapdog is offline
imapdog's Avatar
Originally Posted by Sport Rider View Post
love the look, but please replace that exhaust!
i agree, but will have to be later on. capped out in the pocket book.
i dont know squat about fuel injection, so i am a bit cautious about changing exhaust and not mess up the computer efi. if engineered properly it should self adjust but no one has actually done it yet on this generation 2 motor. wish they have so i would know 100% no issues
Old 02-20-2020, 12:44 PM   #32
The ECU will adjust to the changes in the exhaust.
2020 Kawasaki Vulcan S
Old 02-20-2020, 12:52 PM   #33
imapdog's Avatar
automatically or is there a boot sequence restart ecu thingy?
i am extremely cautious here on changing any intake or exhaust on fi, but i will ride it stock for a while.
and this second gen motor have some sort of turbocharging on it?
Old 02-20-2020, 01:01 PM   #34
The ECU will maintain the proper Air/Fuel ratio. So if the engine can flow more air the ECU will supply more fuel. The only time you would need to program the ECU is if you want to richen up the fuel mixture above what the ECU is programed for or if you wanted to adjust and increase the timing. Now if you add something like a turbo then you would definitely would have to reprogram the ECU. FI doesn't like a lot of timing and would also have to increase the fuel injector size which would need to be reprogramed for. There are performance chips that can increase fuel mixture. https://www.magnumtuning.com/en/subc.../bike-upgrades
Old 02-20-2020, 01:37 PM   #35
imapdog's Avatar
some sort of turbocharging?i read this
"Another advantage about KPM-200 is the 200cc NBF GENERATION II Engine, which adopts turbocharging, crankshaft displacement, roller valve rocker arm, piston spray and other core technologies. It exerts high compression ratio of 11:1, with the max power up to 12.5kw and max torque 17n.m."
Old 02-20-2020, 01:47 PM   #36
I'm not sure what they are talking about but there definitely no turbocharger on your bike. But sounds real impressive. lol
Old 02-20-2020, 01:50 PM   #37
imapdog's Avatar
turbocharging vs turbocharger maybe?
i was comparing this to the cb200 specs. pretty similar comparison.
you know each being 17hp and top speed 77mph.... duel carb vs efi...
as you can see, i am gettin a lot of work done today.
https://www.motorcyclespecs.co.za/mo...onda_cb200.htm
Old 02-20-2020, 01:52 PM   #38
Sure would be sweet if it did have a turbocharger though.
HAHA! That CB200 was my first bike I owned. Same color too (Green).
Old 02-20-2020, 09:02 PM   #39
example. the crashbar/bumper bars. are actually $75 to ship, not the $8 in the ad. keep in mind it will take a month to get it, but good stuff here.
i ordered the crash bars already at about $150 delivered and a wait.
i am debating on the axle mounted fender/plate mount too....undecided
https://www.yoycart.com/Search?Searc...atId=0&catId=0
Based on the pictures from this site, the rear sprocket is plate/bowl shaped. This will make sprocket changes hard if not impossible. What is the tooth count for the front and rear?
Awesome looking bike, by the way. What was the delivered price?
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 02-20-2020, 10:07 PM   #40
whitelightning85   whitelightning85 is offline
that's pretty sweet lookin!
Old 02-21-2020, 09:09 AM   #41
imapdog's Avatar
8 mm-1.25 x 50 mm
in case you are missing the bolts to allow you to clamp the mirrors on, here you go:
you will need x2 8mm-1.25 x 50 mm bolts.
i will mount them tonight, did you even miss them in the pics so far?
Old 02-21-2020, 09:09 PM   #42
imapdog's Avatar
license plate mount
the holes werent matching up so i drilled new ones at 2 1/4" apart to fit on existing bolts from removing the fender. the bolts are attached to metal and is sturdy enough to support a plate hanger.
$8 plate mount:
$6 lights and bolts for holding the plate on the mount all in one. i love these and have used them many times:
Old 02-21-2020, 09:17 PM   #43
imapdog's Avatar
mirrors went on perfect with those bolts i bought
the end caps to hide the bolts came with the bike. took me a while to figure out where they went. nice touch lifan.
Old 02-21-2020, 09:26 PM   #44
imapdog's Avatar
a peek inside while putting the battery in
and rubber inserts to fill the holes where the other location for mirrors would be used. nice touch lifan, those holes were hideous. again took me a while to find out where they went....
btw when i hooked up the battery i noticed the headlights dont come on automatically nor with the high beam switch the passing flasher button did make them turn on. i assume the headlights only turn on when it is started and wont know until tomorrow.
Old 02-22-2020, 01:31 PM   #45
imapdog's Avatar
stock sprockets 16t 49t
