05-08-2020, 09:59 PM | #1 |
Venom X22R 250 performance mods
I got all my parts in and getting ready to start the disassembling of the bike in the morning. I was going to start tonight but got some bad weather coming through right now. I'll video and document the whole process including the porting of the head. Hopefully I won't have to remove the engine which will make it much quicker. Here's a few picture of the surgery table. Lol
05-08-2020, 10:05 PM | #2 |
Awesome Jerry! I can’t wait to see your processes and learn from them so I can do my own build in the future!
2019 Venom X22R K&N pod air filter, removed cat, 105 main jet, 36 tooth rear sprocket, RK racing 428 chain, oil cooler, NGK plug, bar risers, aftermarket mirrors, Grab On grip covers, phone mount/charger, Pro Grip tank protector, Chase Harper tank, tail, and saddle bags. |
05-08-2020, 10:12 PM | #3 |
I wanted to get started tonight but the sky fell out and wind is blowing . I wasn't getting stranded in my shed for the night. Lol. At least the weather is going to be nice and cool tomorrow.
05-08-2020, 10:17 PM | #4 |
Heck yeah. I like that paper shop manual too. That’s nice to have on hand.
My only purchase tonight was the matching set of Chase Harper saddle bags. I needed just a little more cargo capacity than just the other two bags.
05-08-2020, 10:20 PM | #5 |
I printed the manual out today. Lol I'm ready for sure. be sure to post pics of the saddle bags.
05-08-2020, 11:46 PM | #6 |
You let a storm stop you? This was your perfect chance to do a Frankenstein film parody.
05-09-2020, 06:17 AM | #7 |
It would of been perfect with the lightening popping everywhere. It got pretty rough out there for a while. The neighbors old shed got knocked down to a pile of tin. Save him the trouble of having the tear it down himself. Lol
05-09-2020, 11:51 AM | #8 |
Jerryhawkenstein…(cue Beethoven music and lightning)
05-09-2020, 06:08 PM | #9 |
Nice, new pistons and cam, are they thinner gaskets too? I understand cam's and potentially increase compression with thin gaskets but how does a different piston make gains? Is it just in the combustion geometry? I'm a noob when it comes to engines.
Electrician & Electronics Tech 2014 Honda CB500XA 2016 CSC TT250 1976 Honda CJ360T 2022 Honda Navi |
05-09-2020, 06:21 PM | #10 |
High compression forged piston. 11:1 compression and a lighter and stronger piston.
05-09-2020, 06:34 PM | #11 |
Do you have a template for the porting or do you plan to just raise them a bit?
05-09-2020, 06:36 PM | #12 |
Oh so the piston is longer to further increase compression and recessed to prevent hitting all while made of lighter material? The compression rating on a piston is what it would alter the compression too from stock? I always thought it was compression rating the piston will reliably survive.
05-09-2020, 06:39 PM | #13 |
If you had completed the hop up during a terrible storm, when it started, your engine could have sang:
"I was born in a cross-fire hurricane And I howled at the morning driving rain But it's all right now, in fact, it's a gas"
05-09-2020, 06:57 PM | #14 |
Well I got her done. I did take pictures and video but won't be tonight. I have other things I need to take care of but will get then up as soon as I can. I couldn't remove the head and cylinder with the engine bolted to the frame. I unbolted the engine from the frame and let it sit on the bottom of the frame. I was able to tilt the engine to the side a little and removed the head and cylinder. I wasn't to bad. Better than unhooking all the wires and whatever else and removing the engine. The head was about like my hawk head. Exhaust side was restrictive and intake needed a good bit removed right where the intake bolted. Probably 27- 28 mm hole. I did some port matching on the intake side. Now it's a full 30mm. I used a full thickness stock head gasket so my compression ratio is about 10.5:1. I'll probably do a thin head gasket once the engine is broke in and rings are seated.
I got her all back together and she fired right up. Definitely has a thump to it now. I took it out for a short ride to break in the cam and seat the rings. No WOT runs but you can feel more power on the low end and a good bit more on the mid and upper rpm's. I did have to go from a 110 main jet to a 120 and will probably have to go to a 125. I didn't get to install my AF gauge so once I install it I'll fine tune it. I'm happy with the results so far. I'm sure it will feel even better once broke in.
05-09-2020, 08:04 PM | #15 |
Wow. Finished it in a day. That’s awesome, Jerry!
You’re making me REALLY want to go ahead and pull the trigger on the rest of my mods.
