08-09-2020, 07:16 PM | #1 |
Baja DR 125 Rear Brake Bracket
Hi folks! I'm new to these forums, but I've had a Baja Dirtrunner 125 for years! Ride the hell out of it! However, today I ran into an issue.
The bracket that holds the rear brake sheared off - because cheap pot metal. Is this a pretty standard jellybean part or am I going to have to rig something up? If you would kindly point me in the right direction, I would greatly appreciate it! I hope everybody is safe and healthy in these crazy crazy times! Thanks in advance for your expertise! |
08-10-2020, 12:19 PM | #2 |
I'm assuming you are referring to part #2 in the diagram below. If so, the contact information for Baja is in the lower left corner.
08-10-2020, 06:58 PM | #3 |
That would be part 2! Thanks! Also, I thought Baja was long out of business due to bankruptcy and lawsuits from a number of recalls, no?
08-10-2020, 08:37 PM | #4 |
Baja is probably no help to you but give them a try .I ordered and paid for a complete rear wheel assembly for the same bike as yours a long time ago ,like in 2008 or 9 or so ,and it still has not arrived lol .
08-11-2020, 10:21 AM | #5 |
Bruces, you're right, I forgot about that.
DR125 rider, can you post up a few pics of the bracket you have, we might be able to locate a suitable replacement for it. |
08-15-2020, 08:57 PM | #6 |
I should be able to get some pictures tomorrow. I just have to get it off the bike.
08-16-2020, 01:25 PM | #7 |
Here are the pictures as requested. What a pain!
08-18-2020, 02:40 PM | #9 |
Woops! I'm having some technical difficulties on my end with regards to uploading the photos. Sorry about that.
08-18-2020, 02:49 PM | #10 |
It's not you. We are having issues with the website. Working on it.
08-27-2020, 01:18 PM | #11 |
Ah, I see. That is is unfortunate. Welp, I wish I could have found a source for the part, but ultimately, I decided to just take it to a machine shop and have them make one. It's gonna be a bit pricey, but at least it will be done. Only so many days left in the riding season out here in the Northeast. I've heard this bike is a Honda clone, so maybe a Honda part would work? I don't know. I don't have the patience to find out at this point! lol Thank you folkls for all the help and suggestions! I'm sure this wont be the last time I come to the forum for help and input!
08-27-2020, 02:20 PM | #12 |
Just the motor really, sometimes the chassis depending on the bike, but there was only one Honda that came to the States with the CB/CG series of motors that had a rear disc, and this bike isn't a copy of that one.
bracket, brakes, parts |
