Old 10-11-2020, 10:48 AM   #1
OneLeggedRider   OneLeggedRider is offline
OneLeggedRider's Avatar
271cc CG?
Has anyone tried it?
https://m.aliexpress.com/item/400087...0Q90.jpg_.webp
~ Don't poke the bear ~
M.M.I. Dean's List graduate class of '95 and Specialty welder
2020 Ice Bear Terifecta 150cc Trike
2011 Honda Foreman 500ES 4x4
2001 Polaris Scrambler 400
Old 10-11-2020, 11:43 AM   #2
Emerikol   Emerikol is offline
The cylinder in the picture is stamped as a 196CC. That's less than most of us have mounted now. Did I miss how to get to the 270CC mill? I wouldn't mind trying it if it was really a larger displacement.
First Rule of Aviation:
-Never Pass Up The Opportunity to Pee
I was struggling to get my wife's attention; I sat down on the couch and looked comfortable. That did the trick!
My wife says I only have two faults. I don't listen and something else...
If at first you don't succeed, try doing it the way I told you to...
The Stable:
2005 Yamaha V-Star 650 - SOLD
2015 Suzuki DR 650
2015 RPS Hawk 250 - SOLD
2016 Ural Gear Up
Old 10-11-2020, 12:42 PM   #3
2372ighost   2372ighost is offline
2372ighost's Avatar
I scrolled over the pics and found this 300 cylinder
File Type: jpg 28A5D0A1-8244-4F97-80EF-01F18375C984.jpg (157 Bytes, 1059 views)
Old 10-11-2020, 06:26 PM   #4
XLsior   XLsior is offline
XLsior's Avatar
oversized pistons and larger diameter cylinder big bore kits are not uncommon but the issue is the wrist pin along with the jug being able to fit in the case.
the CG250 comes with a 67mm piston and 16mm pin as standard.
the CG200 has a 63.5mm piston and 15mm pin.
I am not familiar with the CG300 but looks to be a 69mm x 17mm
there will be a threshold where over sizing in non viable.
Old 10-11-2020, 06:41 PM   #5
I'm not super crazy about the Hawk powerplant as it is, so rather than trying to polish that turd, I'm thinking about breaking out the cutting torch and welder and making something bigger, more reliable, and decidedly Japanese fit. That would solve a ton of the issues that these bikes have. Please don't misunderstand, though. I'm not unhappy with the bike at all, I just have no illusions about what it can and cannot do. Right now my Hawk is running great (or would be, if I would charge the battery and ride it once in a while), but if the need ever comes up, I think a total heart transplant would be the way to go.
The Stable:
2015 Suzuki DR 650
2016 Ural Gear Up
Old 10-11-2020, 08:05 PM   #6
alex_in_az   alex_in_az is offline
there's a few things we can do to the bikes that improve power quite a bit, I'm not sure how much power they can put out but I have no problem getting mine to into the mid 70s for top speed
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
4 degree advance key
290 degree cam
Nibbi PE30 and cone filter
Front fork brace
Old 10-11-2020, 08:15 PM   #7
When converting 230 to 299. The case is rebored, new connecting rod used new crankshaft.
Is not a drop in replacement.
Reliable? They are UBER reliable. I know cg engines with over 50.000 miles and they are still running strong.
The CG was designed to be reliable, no bells and whistles.
People need to understand the these motorcycle are not made to impress people and ride into the sunset with a gang of bikers. They were made to be a cheap mode of transport.
Old 10-11-2020, 08:45 PM   #8
CG strong, Ride hard!
Old 10-12-2020, 10:11 AM   #9
paulsstag   paulsstag is offline
Originally Posted by OneLeggedRider View Post
I am busy collecting parts to upgrade my Brozz Recon. I have a cam and roller followers coming (early Nov). I will order the 4 degree flywheel key today. Full gasket set is already here just in case. I plan to deck the head 1 mm and port and polish.
The 300 kit is listed on the link one legged posted if you look. It says 70 mm and also 69 mm? either way it is bigger by 2 to 3mm.
This kit is $55 plus $44 shipping so $100 all in ? i am very tempted seeing as my bike is about to be worked on anyway.
Paul
Old 10-12-2020, 01:33 PM   #10
Paul
There are listing for 70mm and 69mm because is not the same if you want upgrade a cg200 or a cg250
It's in spanish, but there is no need to understand it, just take a look at the work done.
In the intro they said that they had to rebore the case by 2mm
