Old 11-18-2017, 12:03 AM   #1
TT250 owners - Question.
Honestly, this could be answered by anybody that knows. Is the TT250 Ignition/CDI AC or DC? I am looking at ways to upgrade the charging capacity of my Hawk, so I am contemplating simply using the Stator setup from the TT250 since it is a lovely 300 watts. However, I do know that many other stators on the market require a switch to DC, and it would be nice to know before I commit.
Old 11-18-2017, 08:38 PM   #2
humanbeing's Avatar
http://www.cscmotorcycles.com/Articles.asp?ID=304 answered ur Q's
Needs these TT250 parts: stator + rotor + reg + CDi
CG "8" often = 88.6mm that can changed to direct-fit "12" https://item.taobao.com/item.htm?id=1651715694 ONLY
93mm (needs new flywheel) config had more options...
Old 11-18-2017, 08:46 PM   #3
I already perused most of CSC's articles on the TT250. That tells me how to test a charging system, but does not mention if the CDI operates on AC or DC Voltage. It just explains how to test a stator and reg/rec unit.
Old 12-22-2017, 10:37 PM   #4
RogerWFarrier   RogerWFarrier is offline
RogerWFarrier's Avatar
You could always call Gerry at CSC. He's the Service Manager and is a wealth of information. When my exciter coil went bad on my TT 250 he was very helpful in helping me with the troubleshooting and getting it back on the road.
2016 CSC TT 250, 17/40 sprockets, JT 428 chain, Stock Keima carburetor with needle raised 1 notch and 115 main jet. Modified stock exhaust, Tachometer/Digital cluster upgrade. LED headlight, Superbrightleds 1157 Tail light bulb, Shinko 705's 90/90-21 and 120/80-18.
Old 01-20-2022, 10:35 PM   #5
BikeLyfeCam123   BikeLyfeCam123 is offline
Somebody Help Me
Good evening, does anyone know where I can get a set of Plastics for my Hawk 250 DLX
Old 01-21-2022, 08:43 AM   #6
Hunnicutt   Hunnicutt is offline
Hunnicutt's Avatar
Welcome to China Riders! I don't know where you can get a set of plastics for your Hawk. Your post could get buried in this thread. Others would better be able to help you if you created your own separate thread.
2021 CSC TT250 - Silver (Mine) "Buzz"
2021 CSC TT250 - White (Wife's) "Seymour"
2021 CSC TT250 - White (Daughter's) "Gemini"
Old 01-22-2022, 11:13 AM   #7
Great Feedback
Thank you for the Info, I will do so right now..
