Old 07-10-2023, 06:08 PM   #1
WD-40   WD-40 is offline
Cam Chain Tensioner BD-125 question
Hi everyone, just bought a 22 BD-125 grom clone from a guy who seemed like he wasn't familiar with the bike. The cam chain tensioner was loose and after taking it off I discovered a washer stuck in the spring.
Should there even be a washer on the bolt?
Is the correct order: Rod with the black part in first, Spring, Washer, and Bolt?
And finally, the Rod has holes in it, does this have an exact fit or is it just to allow oil flow?
Thanks a lot
-WD40
Old 07-11-2023, 01:34 AM   #2
Originally Posted by jeffrey View Post
Rod with black part first then spring,washer then bolt,no exact fit on the rod just put the black part of the rod up.
Thanks!
