Old 04-05-2008, 03:47 PM   #16
katoranger's Avatar
I have found the the no backpressure thing is true if you have done the right mods to accomodate that setup. ie. main jet for more fuel. 2 strokes are a whole nother thing.
Allen
Old 04-05-2008, 05:51 PM   #17
Well you have to do the whole thing you cant get away with just opening up the exhaust alone.
Maybe if you just drill it out a little you might not have as big a impact but what I did was like night and day.(but why even bother for just a little increase )
As I have posted before the K&N airfilter helped a little bit but I got it to run without having to rejet it but a size bigger jet probably would have made it easier to retune but I didnt have the jets at that time.
After adding the free flowing exhaust rejetting was MANDATORY, no way around it it just had to be done but I was ready and just installed bigger jets until I got it to where it is now.
Went from a stock 98 to a 115 and I believe the first larger jet I tried was a 110 and I still feel that a 117.5 would be perfect.
I had several goals in mind when doing mine :
1)get rid of the lousy leaking stock airbox
2)flow more air to increase performance
3)get rid of stock muffler before it starts to rattle apart
4)give the bike a much better sound than that jetsons putt-putt sound
These are some of the simplest mods that return the most performance increase IMO.
I would guess that it has impacted the fuel ecomony a lot but I dont care since mine is a play toy.(top off the tank before every trail ride)
Old 04-05-2008, 10:47 PM   #18
katoranger's Avatar
I rewelded one of the seams on the muffler and can attest to the tin cans.
I think this summer will see the UNI filter and exhaust mods. I need more power now.
Allen
Old 04-06-2008, 02:49 PM   #19
MATT   MATT is offline
In regards to changing the needle position, I found that it is pretty easy to do if you remove the seat and gas tank. Shouldn't take more than 10 minutes.
Old 04-06-2008, 03:03 PM   #20
Dragon   Dragon is offline
This might be a dumb question: why don't manufacturers make bikes with larger jet and free flowing exhaust and save enthusiast the trouble of having to do it?
Old 04-06-2008, 03:07 PM   #21
coleary15   coleary15 is offline
Send a message via AIM to coleary15
b/c they want the consumer(us) to break there equipment, there fore causing us to buy there supplies to fix it and just 2 pi$$ every1 off
just my 2-cents :]
Old 04-06-2008, 04:49 PM   #22
Mountainwolf   Mountainwolf is offline
Matt,
Yea I wish mine was that easy, the way the top of the carb is located on mine I can unscrew the top but it won't come out, hits the top of the frame. Have to remove the carb, PITA. Oh well, got it set right now I thinks.
Wolf
Old 04-06-2008, 04:55 PM   #23
Snake,
Then what would we have to do when the weather sucks and don't wanna ride in the rain? Hell, I spend a good part of my summer wrenching my snowmobile and praying for snow.
Gotta tinker man!!
Wolf
Old 04-07-2008, 09:51 AM   #24
Hey Wolf,
This the exact mod I did on mine many miles ago. However, I did remove everything inside the can with a press. I agree the increase in performance is negligible. So, I just drilled the '07 bike with a home made 5/8" extension bit and left it at that.
Great pics for everyone to see. I like your post. Keep up the good work!!
Jason
2008 Jonway MC-70-150
2007 Roketa DB-07B (RSM-200E)
2006 Roketa DB-07A (RSX-200E)
