Old 08-17-2018, 11:43 AM   #16
DHH 32   DHH 32 is offline
Right now I still have the stock sprockets. I plan on going either 15/40 or 17/45 very soon though. Thanks again.
Old 08-17-2018, 11:57 AM   #17
ChrisWNY   ChrisWNY is offline
ChrisWNY's Avatar
Either of those are good combos and will give you better highway speed. If that chain continues to be an issue, this JT X-ring chain has 134 links and should not end up too tight on those sprockets. You'll likely have to remove a few links before installing...
2018 RPS Hawk 250cc
Mods so far:
1. Mikuni VM26 Carburetor w/#115 main jet
2. 17T/45T JT sprockets
3. JT 428 X-ring chain
4. Air box mod
5. Hawk Digital Cluster
6. Aftermarket IMS shift lever
7. Performance Aftermarket Exhaust
8. 295mm Nitrogen Gas Monoshock, 20W oil front forks
Old 09-19-2018, 11:41 AM   #18
Fantastic Moto   Fantastic Moto is offline
Fantastic Moto's Avatar
Also check the part that keeps the chain in line. It could be pushing the chain as you drive. That's what mine is doing.
Fantastic Moto
2017 Coolster Pit Bike (SOLD)
2015 Green Hawk(Air box opened,Alarm Disabled, China Mikunni carb,105 main jet) (SOLD)
2018 Black Hawk(Air Box opened, Alarm Disabled,China Mikunni Carb,110 Main Jet,Cut out Cat,)
When Life Gets You Down, Remember it's one down the rest are all up.
Check me out on YouTube:https://www.youtube.com/channel/UCKu...EEviZ7IjMmLlEw
Old 02-11-2020, 12:14 PM   #19
Joshcb7   Joshcb7 is offline
Joshcb7's Avatar
Just got a 2020 tbr7,same issue the chain is tight as a drum and the wheel is full forward. Never been rode. Chain has 428H stamped in it? If I removed the rubber chain guide I will gain some slack, maybe enough to ride and stretch the new chain then reinstall the rubber but IDK. Any thoughts?
99 XT225,01 CR250r, 2016 Tao Tao Thunder50, 2019 Tbr7 17T front sprocket 39T rear sprocket 110main jet
Old 02-15-2020, 12:39 PM   #20
OUTERLIMITS   OUTERLIMITS is offline
I'm not that familiar with these bikes, but pictures would certainly help. Most bikes have a frame mounted roller under the swing arm right near where it pivots at the frame. The chain has to go over this roller and not under it. Other than that, I find it interesting that other people with the same bike and same length of chain are not having the same problem with slack. Most bikes just have that roller, a lower chain guide just upstream of the sprocket and maybe a roller a few inches above the chain on the frame. That upper roller and the little plastic chain guard on the top of the swing arm should have no bearing on chain tension at all.
Old 03-18-2020, 02:05 PM   #21
bmw111   bmw111 is offline
bmw111's Avatar
This is an older thread, but I'm having the same issue on my new Hawk 250. The bike does not have any chain rollers -- here's the thread.
