02-19-2012, 04:44 PM | #16 |
I'm not an expert but I would say yes, it will harm the A frames and frame tubes if you drill all the way through them and run long bolts... The frames on these machines are not really a heavy gauge tube and I'm thinking that the possibility of an A arm snapping where it was weakened by drilling would be very high... It would be much better if you could come up with some sort of clamping method. I'm thinking a bracket that goes around the tube and then has a mount to bolt the skid plate on. You could weld tabs on, but then you would ruin the temper in the tubes and they would probably crack down the road as well. Again though, I'm no expert by any means, that's just my 2 cents. Theyre looking great by the way, aluminum is nice to work with isn't it?
02-19-2012, 06:01 PM | #17 |
something like this should work (got the idea off a honda forum)
attach 6 to each plate and then bolt to a-arm? this would also give me the space needed between the a-arm and the plate
I could be wrong......it has been known to happen<div><br /></div><div>core directive 172: No member of the core shall report for duty wearing a ginger toupee</div> |
02-19-2012, 06:13 PM | #18 | |
02-19-2012, 07:40 PM | #19 |
well this is as far as I can go now till i get the brackets and hardware to mount them
even counter sunk the mount holes I think that was a good way to waste the weekend. 8)
02-19-2012, 07:42 PM | #20 | ||
02-20-2012, 07:36 PM | #21 |
ok so finding these hangers locally is out of the question but will go to abbotsford and check there :roll:
other than that you can find them on e-bay at not to bad prices BUT they want $15 to ship "2" (on one i looked at) and another had a box full for around $40 and wanted $60 ish for shipping :evil: this could be frustrating and kinda comical as well
02-20-2012, 10:01 PM | #23 |
Those look uptown!
If you drilled through the frame, inserted a piece of DOM tubing in the holes and welded it in, I think the strength compromise would be negligible. Your clamp idea is much faster and easier, though.
02-20-2012, 10:12 PM | #24 |
havn't drilled through the frame or a-arms yet ...want to go with the clamp ider 8)
02-20-2012, 10:15 PM | #25 |
hoping home depot has these brackets.
02-20-2012, 10:24 PM | #26 |
Any of the electrical wholesalers should have them.
03-02-2012, 07:51 PM | #27 |
went to a suplier in abbotsford today and they do not have them in stock but will have them here by next week......and at $.70 each I can wait.
03-02-2012, 11:25 PM | #28 |
Alternately, you could buy u-bolts at princess auto! I used a similar concept when I built the skid plate on my bike. Just make sure you locktite the crap out of the bolts!
03-02-2012, 11:30 PM | #29 | |
03-03-2012, 01:38 AM | #30 | ||
