06-09-2017, 10:52 PM | #1 |
Hawk 250 Fork swap.
if you go to http://www.allballsracing.com/index.php/forkconversion
and put in Dirt/ 1992 / Honda /XR200R you will find a list of forks and conversion bearing kits for many bikes.. within reason any will work. I bought a set of 1984 xr350 forks and triple tree. found this line and ordered the bearings.. Honda XR350R 1985 26 47 15 99-3520-5 26 47 15 99-3520-5 Tore down the hawk.. removed the roller bearing races "keep em to drive the new ones in place". installed the new taper races "perfect fit" and the new bearings onto the xr triple tree. "keep old bottom inner race to use to drive on the new bearing. installed the tree and forks "perfect fit, close to the tank at full turn but no hit." They are 41mm and longer so I have about 2" poking above the tree, to keep the height right. |
