11-07-2017, 01:13 AM | #16 |
well I have a whole one liter bottle..... Dose that count
And I'm going to recycle it... dig a hole and tip it in... 12 5 q jugs or 7 5 gal buckets.... hard to pick a winner there... and then yer toss the 15 gal keg into the mix it even gets harder... Ok guys it will have to be a draw..... ..
11-07-2017, 02:23 PM | #18 |
Break-in procedure threads come to the same consensus as oil threads. Everyone has their own experiences and opinions.
Mine? "Harder" break-ins on two strokes, factory recommended break-ins on four strokes.
11-07-2017, 04:10 PM | #19 |
Thanks everyone for your input. The members replying to this thread who have proven to me to be the most helpful and most thoroughly-informed and knowledgeable members replying to my posts on this forum have each expressed their favorability to the 'hard break-in'.
I am glad to have reached my decision and am following the advice of the members here who have proven their credibility to me here over and over again! (Hint-hint...JerryHawk250 and Megadan -- THANK YOU SIRS!) |
11-07-2017, 09:11 PM | #20 |
It says your a tree hugging liberal that sniffs their own farts
11-07-2017, 10:00 PM | #21 | |
Hawktwofifty, just be vigilant and methidical. Pushing any motor hard always has an inherent risk. So the more attentive and cautious you are, the better. Or I am a micro oil baron bent on world destruction...
11-08-2017, 01:01 AM | #22 |
[QUOTE=
Or I am a micro oil baron bent on world destruction...[/QUOTE] and sniffs his own farts!
11-08-2017, 02:18 AM | #23 |
11-08-2017, 11:34 AM | #24 |
I did mine pretty close to Dan's hard break in, lots of initial mild heat cycles and oil changes in between. Maybe why mine will do 62mph with 17/50 sprockets combination?
1991 Kawasaki KLR250 |
11-09-2017, 05:12 PM | #25 | |
"In my experience", which is all I can speak from, I've seen more than a few four stroke motors lock cams in cam bearings and snap chains because the new owner whipped the snot out of a new motor and the "hot spots" seized up before they could completely mate surfaces. To each their own............
11-09-2017, 07:28 PM | #26 |
11-10-2017, 07:38 AM | #27 | |
11-10-2017, 09:13 AM | #28 | |
11-10-2017, 09:51 AM | #29 |
So here's my two-cents worth on this topic. I've been tinkering with engines for everything that has wheels, and most things without. I've rebuilt two aircraft reciprocating engines, a whole mess of jet engines (thank you Air Force) and boat, auto and motorcycle engines galore. What I take away from all that experience, but most specifically the aircraft engine experience is this: You can't do a gentle break in on an aircraft engine. You'd run out of runway before you ever got it off the ground. I think that Megadan has a reliable, methodical practice laid out that closely mirrors what happens when you rebuild an aircraft engine. Run it on the ground for a bit to make sure you don't have any leaks or it's not making expensive sounding noises. Shut it down and let it cool while you top up the fluids and inspect everything. Then, GO FLY! As part of the take off requirement you'll have a hard full throttle run to get airborne and up to altitude, and then you adjust power for cruise. Do some flying to benchmark the performance, and then you reduce power and land. All in all, my takeaway mentality is to break the engine in the way you intend to use it. Breaking in an engine is one of those things that everyone has an opinion on or does differently. I say do what makes you the most comfortable because you're the one that has to live with the results.
11-10-2017, 02:24 PM | #30 |
dirt / race bike...
easy for the first tank of fuel... and then ring it's neck.... road / duel sport / ADV... don't sit at constant revs for to long to stop the bore glazing up... Don't use full syn oil... can stop / slow the running in process.. Use semi syn or dino... ...
09 XT660R ... 06 TTR250 ... 80 Montesa H6 125 Enduro... 77 Montesa Cota 348 MRR "Malcom Rathnell Replica"... Current resto projects.. 81 Honda CT110... 80 Kawasaki KL250A1... 11 Husaburg TE125 enduro... "sold" along with another 31... Lifan 125 Pitbike.. "stolen" ... KIWI BIKER FORUM...... http://www.kiwibiker.co.nz/forums/content.php All the best offroad rides in NZ... http://www.remotemoto.com/ E-mail... xtpete1@gmail.com Last edited by pete; 11-10-2017 at 04:03 PM. |
