04-26-2018, 09:23 PM | #1 |
Zongshen 223cc oil cooled valve clearence?
Hello, i have a 2015 oil cooled engine.its 223 cc sold as model Falcon Freedom 250 in Turkey... link
at youtube i see a german guy that says valve clearence is 0.03mm but if there is still noise you can do it 0.02mm... Another guy says 0.03 in-0.04 out... another guy says its 0.06-0.8 Which one is it ? unfortunatelly i dont have manuel and the services doesnt want to tell because they want to do it and take money I did it 0.03-0.04 but didnt start it to be sure... Thanks. RESULTS AFTER A MONTH: hello again...i tried 0.03-0.04 for some weeks with the youtuber advice and i saw that the engine was too hot and burned my oil and legs in a very short period...performance was wonderful but you feel that engine gets stuck to much from pressure... after that i tried 0.05 which @emerikol adviced... and the engine is happy now...heat is gone and is normal now... also performance is very perfect and the engine is also happy but i feel a little bit pressure in the engine so i will try 0.01 more and share the result.. Also from youtube, some guy posted something from handbook and i believe its the correct clearence... Im Handbuch ist zu lesen "intake gap should be 0.06-0.08mm" exhaust gap should be 0.08-0.10mm" will try and share my results thanks. Last edited by mefairo; 06-01-2018 at 07:08 AM. |
Tags |
223cc, valve clearence |
