05-23-2018, 06:40 AM | #16 |
Gas Siphoning from cap fix
Filled her up yesterday and we have a winner!! No more gas coming out of the tank. I put in 2.5 gals and no leaking.....
So take of the excess material from the cap with a dremel cut off wheel let it end right at the bottom of locking teeth.
2016 Brozz |
05-23-2018, 07:51 AM | #17 |
Glad to see you got it fixed.
05-23-2018, 09:17 PM | #18 |
Could you post a pic of your modified gas cap.
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic. |
05-24-2018, 06:36 AM | #19 |
It will be a while before I do but really All you need to do is cut it off flush with
the bottom of the teeth. Look at the picture below an imagine the cap ends at the teeth. Get a screwdriver a pry that black cap off you will then see inside and see where you want to make the cut.
2016 Brozz |
