02-25-2019, 07:24 AM | #16 |
Make sure you are adjusting idle at throttle adjuster on thebars first before you mess with the idle screw on the carb also how many turns out is your a/few screw? 99% of the time a vacuum leaks is the cause of high idle. I can't get u current pics due to bike is out in the shed and there's a foot of snow and it's -10 out side. Take your side plastic off and look for vacuum leaks. Check a/f might be running lean. I believe if u have it turned out 3 turns or more u need to go up 1 jet size. Should be out 1.5 to 2 turns but correct me if I'm wrong
2018 BD125-8-x21rs ZS190/Genuine PE28 Kepspeed GP1 Exhaust Protaper se x110 bars/grips 1/4 MotionPro throttle Kepspeed Braced swingarm Chimera rear hub assy Grom Intergrated tail light Superlite Sprockets 17/32 custom made from Japan Chimera Swing Arm Bolt RK MXZ Chain #420 All Balls wheel bearings Motodynamic fender eliminator Coremoto ss brake lines Composimo 2.5 lower link Grom Calipers-w/ebc pads/rotors Michelin tire 140&120 13x4/13x7 fatties Grom forks |
02-25-2019, 07:36 AM | #17 |
Sounds to me if u removed canister and idle increased you have a vacuum leaks somewhere
02-25-2019, 07:44 AM | #18 |
Do a search for "high idle" on this forum, there are several threads about it and what people did to fix them. Sry I can't get you pics right now. Maybe I can get out there later today. Got to hit the sack for awhile. Be back later.
02-25-2019, 08:19 AM | #19 |
Got it idleing at 1 .5k, plugged the hole leading to the head with a bolt and some hose , and the crankcase vent left open. Only thing I notice is when I give it more revs sometimes it hangs up for a sec then goes back down, other than that all seems a ok gonna take her for a ride in a sec
02-25-2019, 08:27 AM | #20 | |
02-25-2019, 11:31 AM | #22 |
Took her out got it to 50mph at around 8k rpms or so and was running fine. After she warmed up well after a few mins seems like it cuts off on the upper rpms? I'm guessing too rich? Running the 110 main
02-25-2019, 11:38 AM | #23 |
Allow 300 miles or so for break in, rings to seat before you push to hard.
02-25-2019, 03:00 PM | #24 |
Don't forget to post some pics, we all like those!
02-25-2019, 03:12 PM | #25 |
Good advise.
02-25-2019, 06:50 PM | #26 |
Gonna start the tuning tomorrow when I'm off, I appreciate all of your help and I'll definitely take it easy the first 300 miles, she's at 22 right now lol almost my age haha
And here she is https://imgur.com/a/wXpwRcP |
02-25-2019, 11:25 PM | #27 |
Nice and unmolested, give it time then your wallet will start getting thinner for goodies for your bike. My bike only has a little over 300 miles and I'm already about to swap in the zs190cc, not for the higher speeds but mostly for the 5 gears and a little more go. Oh well. It's only money right.
02-26-2019, 03:30 AM | #28 | |
02-26-2019, 10:50 AM | #29 |
Glad to see you got everything up and running.
If you don't have one already, I'd recommend getting a clocking flange on ebay ($6). That way you can rotate the carb around so that the filter doesn't rub on the front fender on big dips and tuck the filter away towards the rear a bit. |
02-27-2019, 12:43 AM | #30 | |
