05-07-2020, 07:38 AM | #16 |
As promise, here's the rear sprocket with the steel ring recessed complete wit a nice coat of limestone dust from the parking lot at work.
05-07-2020, 10:53 AM | #17 |
What specs do you need for the sprocket with the cut out? I am going to order one soon and want to get it with that cut out.
05-07-2020, 10:58 AM | #18 | |
I’ll post my measurements of the stock one and aftermarket one for comparison when I work on the bike Saturday. I might even get to it tonight.
2019 Venom X22R K&N pod air filter, removed cat, 105 main jet, 36 tooth rear sprocket, RK racing 428 chain, oil cooler, NGK plug, bar risers, aftermarket mirrors, Grab On grip covers, phone mount/charger, Pro Grip tank protector, Chase Harper tank, tail, and saddle bags. |
05-07-2020, 11:35 AM | #19 |
I don't have that information right off hand. I didn't measure the ring. I just traced out the steel ring while it was on the hub.
05-11-2020, 04:46 PM | #20 |
Got the sprocket pocketed today with a carbide bit I'm my Dremel lol. Where there was a will there is a way. Looks good and fits snug. Also while I had the Dremel out I installed an under tail bracket to get ride of the big ol ugly fender.
2018 Venom X22R 18/34 sprockets, NGK spark plug,reflective rim tape, phone mount/charger, CNC tag bracket,LED headlights, LED anti flicker, oil cooler, gutted cat, sai delete, titanium exhaust wrap, 115 main jet stock carb, pod filter and airbox delete, Kawasaki 400 stainless muffler. |
05-11-2020, 04:49 PM | #21 |
Sprocket looks like mine. I works.
I like the licence plate bracket.
05-11-2020, 05:12 PM | #22 |
Had to be blue to add to the color pop
05-12-2020, 10:11 PM | #23 |
Just a quick look at the bike before my ride home. Got the LED in today. Need to figure out how to get them adjusted up a little bit though but I can now see more than 20 feet in front of myself now so that's an improvement.
05-13-2020, 04:14 AM | #24 |
Are you able to angle the plate out at all or is it fixed straight up and down like that?
05-13-2020, 08:02 AM | #25 |
There is a hex head screw on the back of the headlight housing.Turn it CCW to raise the beam. At first i thought the screw wasn't doing anything because i was turning it CW so i shimmed out the top of the headlight housing with rubber washers. I figured it out later i was turning the screw the wrong way.
05-13-2020, 09:19 AM | #26 |
The bracket is fully adjustable. That's just where i set it.
05-13-2020, 09:21 AM | #27 | |
05-13-2020, 12:39 PM | #28 |
How’s that 18 tooth sprocket doing? Any problems with rubbing?
Also, what are your rpms at 60mph gps? I’m guessing 5500?
05-13-2020, 01:35 PM | #29 | |
At 5500 rpm in 5th gear I'm running 65mph. Without doing more performance oriented mods at this time my top speed seems to be 72mph on the GPS. Just doesn't have the balls right now for the gearing lol. Also shameless pic of her inside because I can.
05-13-2020, 03:58 PM | #30 | |
Wow, 65 at 5500. That’s awesome. I turn 6500 at 65 which isn’t bad, but 5500 would be an even more comfortable rpm. My top speed with a 17/36 combo is 74 so I’m right there with you. I bought the 11:1 compression 233cc big bore Athena kit and I’m going to also port the head and buy a cam. Once I do that, I might try the 18/34 gearing because then I’ll have the torque to comfortably pull rpm.
