Old 02-04-2007, 07:14 PM   #16
VFRFLYER   VFRFLYER is offline
Originally Posted by shadowred
I had a lot of problems with my brakes seizing and I found that my brake line was not lined up correctly which was stopping the fluid flowing back from the brake.
Can you elaborate a little more on what not lined up means. Fatboy250 and I did about 75 miles this past Sat and I had to stop twice to bled the rear disc Im thinking this must be a design flaw. for this many bikes having the same issue. but maybe we can correct it
06 Roketa RSX 200E (DB 07A)
Old 02-06-2007, 08:59 AM   #17
ejcycles's Avatar
Hey Guys
There is an adjustment rod below the rear master cylinder with a lock nut on it that goes to the rear brake arm. You need to adjust more free play in the arm to stop them from locking up. I hope that this helps.
Bruce
Old 02-06-2007, 10:32 PM   #18
Hey Bruce
I appreciate the help! do you mean to loosen that jam nut to allow some movement I ve seen the rod you are refering to. should it be adjusted out longer. there is also a stop bolt to control the height of the pedal. ahh heck Ill just turn some stuff and see what happens LOL
Thanks Ray
