Old 05-08-2015, 01:02 AM   #3391
Originally Posted by G19Tony View Post
When I got the new battery in, I started the engine for about 30 seconds. The oil in the sight glass went away, as expected. It's been 4 hours and nothing has drained back to the case. Did I do something wrong when I did the oil change? No leaks noted. I'll check again in the morning.
How much oil did you use to refill the engine? I suspect you will find the oil visible in the sight glass tomorrow morning. However, it is unusual that the oil didn't return to the sight glass within minutes.
Old 05-08-2015, 01:22 AM   #3392
G19Tony   G19Tony is offline
G19Tony's Avatar
I filled it to the full mark. If there is no oil indicated, I'll be calling CSC. Strange problem, indeed.
Honda CB300R ABS
Old 05-08-2015, 01:29 AM   #3393
If you didn't measure the amount of oil, that's the problem. You didn't add enough oil to the engine. If you fill the oil to the proper level in the sight glass, then start the engine, the oil will be distributed to the nooks and crannies of the engine. Also, if you install a new oil filter, some of the oil will be distributed to that area. Therefore, you need to fill the oil to the appropriate level in the sight glass once again, run the engine, and keep doing so until the oil returns to the proper level in the sight glass within a few minutes of stopping the engine.
I simplify the process by measuring 1.7 quarts (55 ounces) of oil to add to the engine. Using this method, I know I have the correct quantity of oil. Of course, I verify the oil level is correct after running the engine, and checking the oil level in the sight glass.
Old 05-08-2015, 01:32 AM   #3394
G19Tony's Avatar
If you didn't measure the amount of oil, that's the problem, Tony. If you fill the oil to the proper level in the sight glass, then start the engine, the oil will be distributed to the nooks and crannies of the engine. Also, if you install a new oil filter, some of the oil will be distributed to that area. Therefore, you need to fill the oil to the appropriate level in the sight glass once again, run the engine, and keep doing so until the oil level returns to the proper level within a few minutes.
Well, ok then. I'll be adding oil again tomorrow, but I believe I have around 1.5-1.7 in it now. If you dump all 55 ounces in, the oil will go above the fill line, correct?
Honda CB300R ABS
Old 05-08-2015, 01:35 AM   #3395
Yes, the initial 55 ounces might fill the oil above the proper level in the sight glass. However, after you run the engine, and the oil is distributed throughout the nooks and crannies of the engine, the oil level will drop to the appropriate level in the sight glass.
Old 05-08-2015, 01:43 AM   #3396
You can certainly change the oil in the manner you employed. However, you need to continue adding oil, running the engine, and checking the oil level. You must repeat this procedure until the oil returns to the appropriate level in the sight glass within a few minutes of stopping the engine.
I find the job much easier to merely fill the engine with 1.7 quarts of oil. Repeated experience has proven this is the correct quantity of oil. The oil level doesn't have to be exactly precise. A little extra oil will not harm the engine, since it will be blown out the crankcase vent tube, pass through the oil separator, and collect in the clear tube at the left, front side of the engine. If you measure 1.7 quarts of oil, you will have enough oil to safely lubricate the engine, but not so much oil that it can't be safely removed by the crankcase ventilation system.
I fill 1.7 quarts of oil, and I don't have any oil collected in the tube beneath the oil separator.
Old 05-08-2015, 01:49 AM   #3397
If you ran the engine for a few minutes after adding engine oil, you certainly didn't burn much oil, especially with a new motorcycle. Therefore, if you don't have an oil leak, you didn't add enough oil.
I suggest you add oil to the appropriate level in the sight glass tomorrow morning. Then run the engine for about three minutes. After stopping the engine, wait about three minutes for the oil to settle. Check the oil sight glass, and repeat the procedure, if necessary, until the oil returns to the proper level in the sight glass.
Old 05-08-2015, 02:37 AM   #3398
G19Tony's Avatar
Emergency terminated. It was a measuring error on my part. Nothing to see here. Move along...move along.
Honda CB300R ABS
Old 05-08-2015, 02:51 AM   #3399
Old 05-08-2015, 08:19 AM   #3400
Huck369   Huck369 is offline
Huck369's Avatar
Friday Pic
It's Friday!! posting a TGIF Pic!
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 05-08-2015, 08:41 AM   #3401
I see you got one of the fastest, orange bikes, and you mounted a J.C. Whitney Travel Trunk on it! The handguards look good, Huck.
Old 05-08-2015, 09:47 AM   #3402
My Taobao shipment which includes my upgraded LED headlight just arrived in San Francisco, and is heading over to customs.
Old 05-08-2015, 11:27 AM   #3403
It took a lot of washers, but I got the spring on.
Glad to hear that. I've shared that tip many times, and it's all thanks to the gentleman who shared it with me. I'll let him know.
Old 05-08-2015, 11:30 AM   #3404
katflap   katflap is offline
katflap's Avatar
Fuel Injector Leaking ?
I have noticed over time that my oil level has been rising. At first I thought I was just imagining it. But I think now it could be the case.
So I have set up some marks on the ground and selected a block of wood for under the side stand.
This combined with a small mark I have made on the oil level inspection window so I can accurately monitor the oil level each time I check.
This I did last week. Today I checked the oil level and It does seem to be starting to rise.
Also when I initially set this up I removed an amount of oil to gain the correct level. This oil reeked of fuel, I don't mean a small whiff of petrol, it totally stunk of the stuff.
Probably best if I order a new injector before I start ripping things apart
Old 05-08-2015, 11:33 AM   #3405
Huck369's Avatar
Thanks! I'm really enjoying it!
Huck
2013 Honda NC700X
2016 AJP PR4
2022 Templar X 250
AMA Life Member
