Old 05-16-2015, 10:38 PM   #3526
I just completed a 12-mile ride across town for groceries. I mounted my Garmin GPS receiver, and recorded the odometer setting. Then I zeroed the trip odometer on the RX3 before departing.
I don't know the accuracy of a GPS odometer. However, here are the results.
Trip distance recorded by Garmin GPS receiver: 12.1 miles
Trip distance recorded by Zongshen RX3 odometer: 12.8 miles
My Garmin GPS receiver records hundredths of a mile, while the RX3 odometer only records tenths of a mile. Therefore, I don't know how close the stock odometer was to reaching 12.9 miles. However, using the most conservative estimate of 12.80 miles, I performed the following calculations.
12.8 miles minus 12.1 miles = 0.7 miles 'optimistic' on the odometer
(0.7 miles divided by 12.1 miles) x 100 = 6 percent 'optimistic'
Using the same, Garmin GPS receiver for comparison, the stock speedometer is running over 10 percent 'optimistic.'
Old 05-16-2015, 11:44 PM   #3527
woodlandsprite's Avatar
Originally Posted by G19Tony View Post
I don't think any of that is installed on a shipped bike.
Originally Posted by rjmorel View Post
My was not installed on the bike either but it was included in the boxes of guards and rack mounts. rj
I paid to have my bike assembled and shipped. They were going to install the accessories purchased with the bike at the same time...they didn't tell me there were things not available when they called me for payment and shipping.
Old 05-17-2015, 01:14 AM   #3528
G19Tony   G19Tony is offline
G19Tony's Avatar
I paid to have my bike assembled also. I drove down in my truck and picked it up. They didn't have the power ports available, but they sent them to me quickly, and the ports were easy to install.
Honda CB300R ABS
Old 05-17-2015, 11:52 AM   #3529
Jaume   Jaume is offline
Jaume, don't forget to run the inner tube valve securing nut up away from rim tight onto the plastic cap. This way if your tire slips on the rim ,it won't rip out the valve stem and you can see if the tire slips on rim , as the valve stem will be bent over. rj
Thanks for the advice to everybody. I'll check this carefully. I'll fill the inner tubes the next week, preparing the trip (waiting for a couples of days with good weather)
Old 05-17-2015, 01:55 PM   #3530
Originally Posted by pete View Post
Just a pitty Honda don't import there XR400 based ADV bike here...
Honda XRE400 Falcon...
I feel the same way, although it would be ridiculously priced in Canada.
Old 05-17-2015, 03:37 PM   #3531
oldqwerty   oldqwerty is offline
Hondas are ridiculously priced in the U. S. of A., which is why I didn't but a 700. They are limited ground clearance and suspension travel, with a very low center of gravity, and lots of good attributes for adventuring, but they cost too much once the farkles that come with a Cyclone are added,
"Thou shall not Zong" is not a commandment.
Old 05-17-2015, 04:10 PM   #3532
That is very well stated.
Old 05-17-2015, 05:23 PM   #3533
Sometimes I get lucky.
Old 05-17-2015, 07:05 PM   #3534
G19Tony's Avatar
Hopefully, Honda will take note of the RX-3 and make some adjustments. Competition is good for everybody.
Honda CB300R ABS
Old 05-17-2015, 09:28 PM   #3535
Indeed. Perhaps the sleeping giant can be awakened.
Old 05-18-2015, 02:06 PM   #3536
DanKearney   DanKearney is offline
If we pick the bike up at the dealer, we have to pay to have it assembled?
Cheers,
Dan K.
Dan Kearney - Black Hawk, Colorado, USA
Dan's Motorcycle Blog - "Lost? I'm not lost. I'm just exploring. . ."
Old 05-18-2015, 02:30 PM   #3537
Unless you are accepting it in its shipping crate, and doing the assembly yourself then yes, you will need to pay for assembly. They charge $195 for assembly if i remember right.
Old 05-18-2015, 02:42 PM   #3538
Thanks,
Dan K.
Old 05-18-2015, 05:44 PM   #3539
G19Tony's Avatar
Cheers,
Dan K.
My intent was to ride it home, so I paid the assembly fee.
That is correct WS.
Honda CB300R ABS
Old 05-19-2015, 02:51 AM   #3540
Today I removed the stock trunk from my Zongshen RX3, and installed a large, Garage Pro Travel Trunk I had purchased from J.C. Whitney.
http://www.jcwhitney.com/garage-pro-...7&&filterid=u0
Using a 20% off coupon, and free shipping, you can purchase this travel trunk for less than $40, delivered. This travel trunk locks to the luggage rack on a steel mounting plate. Therefore, you can remove the trunk from the bike and take it into your motel room, tent, et cetera, at the end of the day. You can also remove the trunk if you wish to lighten the bike for daily rides.
You can read my installation thread for this travel trunk at the following link.
http://www.chinariders.net/showthread.php?t=14712
