03-31-2019, 12:15 AM | #407 |
The Bambino had his first ride in the Ural yesterday. We went around the block while the Missus held him in the sidecar. He was much more interested in flipping the switches in the sidecar than actually realizing what was going on. Oh well, he's young, there's still plenty of time to get him infected with the motorcycle bug.
http://www.chinariders.net/attachmen...1&d=1554005653
03-31-2019, 07:52 AM | #408 |
Cool beans. Start them young.
My youngest grandson will get his first solo ride later next month.
03-31-2019, 09:15 AM | #409 | |
03-31-2019, 09:39 AM | #410 |
Almost true. Ginny is getting up in years. I’ve watched her reasoning whether or not it’s worth the effort to get off her comfy chair for food.
Unless it’s pizza. Pizza is definitely worth it.
03-31-2019, 10:56 AM | #411 | |
Throw a slice a pizza in the sidecar ,then get behind her with a scary vacuum cleaner .Instant sidecar friend ! . |
03-31-2019, 12:24 PM | #412 |
Our late, short for his weight beagle would have been in the tub without any coaxing. The Iggy probably would have, too. They were pretty calm in a canoe.
04-07-2019, 08:47 AM | #413 |
Out on the pickemup truck yesterday. Two cans of gas for the mower and chipper, plus four 8’ pieces of trim for continuing honey do projects.
04-19-2019, 06:34 PM | #414 |
Mod Day today. New deeper oil pan.
Kind of a slight pain in the butt to change out. One frozen bolt that released with a bit of heat. A lot of casting flash needed to be removed from the new pan, along with chasing the drain plug threads, and finishing the bolt holes. Now I know why I only paid thirty bucks for the pan. The spin on oil filter is not to be just yet. My rig has a crossover exhaust pipe that interferes with getting the filter on. Solutions are, 1) Keep using the cartridges. 2) Remove crossover pipe. 3) Dent the crossover pipe. 4) Bring a case of beer to my friends machine shop and have him face off about 1/4-3/8" thread from the adapter. Doing number 1 now and eventually number 4.
04-28-2019, 10:48 AM | #415 |
In prep for an upcoming trip next month, been doing the mods, a tune up, and various checks.
Tune up consists of new plugs, valve clearances, carb balance, and idle adjustment. Plugs, two years old, looked fine but new are cheap insurance. Valve clearances are .004” for both. Left jug was perfect, right was .005 and a tight .004. Both are the same now. Carbs were good, just needed an idle adjustment. For the first time since I bought the rig, I pulled the petcock the check the in tank filters. I hear horror stories about them getting crudded up and causing fuel issues. Not a bit of crud on mine. Decided to do a side by side comparison between the RPOC and the Maggot regarding problems. Bought the Maggot in 2010 with 20K on the clock. Up to 27K now. In that time, the engine has been out twice. Once for broken timing chain guides and once for stator replacement, (which probably wasn’t needed). Spent months chasing a mid range rpm miss which turned out to be the ‘new’ coils. Put the original coils back in, no more missing. Replaced the tired stock CDI box with a FinnBoxG47, and then with an updated FinnBox. Ran great...until the low speed coil on the replacement stator failed. Choice was either pulling the engine a third time and replacing the stator with another crap shoot rebuilt, which, by the way, would require replacing the water pump seals. Again. Or, look into an Aussie developed and built Hall Effect ignition system with a microprocessor. Australia won, and it looks like it was a good choice. First set of replacement tires are going on soon. Largest outlays of cash were for ignition systems. Purchase price of the bike was $600. RPOC is a heck of a lot newer, 2007 vs 1979, though much of the technology is 1950s. Had 15K miles on the clock when purchased in late 2016 for $6200. At 25K now. Other than the FD fiasco last year, removing the PO finger prints, and speedometers, have had very few problems. Largest outlays of cash have been for tires and fuel. The rig gets about half the mpg of the Honda and requires premium fuel. Sidecar tires wear funny and quickly. I’ve learned if you rotate between the hack and pusher tire, you can get a pretty good increase in tire life. Even better if throw the spare into the mix. Both have their high points and low points but I think the RPOC grin factors are greater.
05-09-2019, 11:09 AM | #416 |
The Ural requires premium? Is that due to high compression or just an antiquated head design?
05-09-2019, 07:12 PM | #417 | |
The Maggot has a CR of 10.0:1 and requires 89. Go figure.
05-09-2019, 11:09 PM | #418 |
I run premium in all my motorcycles, and usually the first tank of a long road trip in the Suburban. I think it's cheap insurance on the motorcycles, and I like to think that for a long road trip in the Suburban, a tankful of premium helps to clean everything out since the engine will be whizzing around at full operating temperature for an extended period of time. just my two cents worth, but for the cost of premium in the bikes, and the occasional 40 gallon fill up in the Suburban, it's not going to break the bank.
05-10-2019, 12:18 PM | #419 |
I hadn't considered the cooler intake charge. Makes sense. As long as it will light premium at that compression ratio, I'd do it.
07-18-2019, 03:41 PM | #420 |
More truckster duties yesterday. Just made it into the garage before the skies opened up.
