12-17-2018, 08:24 PM | #31 |
Looks like the Pitster Pro 400 is no longer available.
http://www.chinariders.net/showthread.php?t=8076 |
12-17-2018, 09:19 PM | #32 | |
12-18-2018, 11:21 AM | #33 | |
http://www.chinariders.net/showthread.php?t=8930
12-18-2018, 12:44 PM | #34 | |
12-18-2018, 02:35 PM | #35 | |
12-18-2018, 03:23 PM | #36 |
It was Xingyue OEM. The Xinyue bikes were EPA/DOT certified for a few years, including selling them through Pitster Pro, but had a fatal engine flaw that could not be fixed.
12-18-2018, 03:31 PM | #37 |
On the EPA/DOT certification list, Bashan is stated as the mfg. However, they OEM BMS's new enduro, the CRP 250, and BMS proudly states the engine is Zongshen OEM, so I tend to lean that way, that Bashan's engine OEM is Zongshen. TMEC's 196cc engine's OEM is Zongshen, but on their EPA certificate it states TMEC as the mfr.
12-18-2018, 09:04 PM | #38 | |
I could well be wrong tho. It wouldn't surprise me if they claim things to get around the rules lie they do in China, loads of fudged things |
12-18-2018, 09:06 PM | #39 |
The Wild Alaska acording to Spud was the Shineray X2 bottom end (250cc and weak) plus a Rotex 400cc top end.
X2 they busted their 2nd gear and then add on a much bigger CC top end............... |
12-19-2018, 07:26 AM | #40 | |
2016 Brozz |
