Old 07-06-2016, 04:49 PM   #31
MDStroup   MDStroup is offline
MDStroup's Avatar
Originally Posted by JohnDoe2887 View Post
Are you sure the would work with a motor so small? I see why you suggested the VW smog pump after following you link vary interesting....
I have no idea if it will work. But if it can be done that is probably the best route to try first.
I just wish these bike came with OHV. The predator engine are honda clones with OHV. The most popular is the 212cc. It is used for go-karts every where. it only costs $100 and is modifiable like crazy!
That motor starts off at only 6.5HP. People get that engine up to 32HP. The only billet required internal is the connecting rod.
I know for a fact that people have super and turbo charged that motor.
http://www.kemotorsport.com/cafe.htm
Here is a 50cc bike that is using the VW smog pump.
I think the easiest way to super or turbo charge the hawk 250 would maybe convert it to EFI with a EFI from a scooter. If I am remebering correctly someone did that to a Ninja 250 over on the Ninjette form then added the ecotron turbo.
Old 07-06-2016, 06:39 PM   #32
JohnDoe2887   JohnDoe2887 is offline
JohnDoe2887's Avatar
Hum I will look into that more.... What is EFI when it's all said and done? Mad air flow a O2 sensor and a fuel system no? (Depending on cost I wonder if my own couldn't be scratch built. For about same if not less
Sincerely,
John Doe
"All forms of madness, bizarre habits, awkwardness in society, general clumsiness, are justified in the person who creates good art." -Roman Payne
"Truth is stranger than fiction, but it is because Fiction is obliged to stick to possibilities; Truth isn't." -Mark Twain
"I have never made but one prayer to God, a very short one: Oh Lord, make my enemies ridiculous. And God granted it."
-(Letter to Étienne Noël Damilaville, May 16, 1767)
Old 07-06-2016, 07:04 PM   #33
This was my question, how. I see , thanks for posting the link-radical dude
I believe the full blown (excuse the term) ecotron efi system or the motorcycle is like $700.
http://www.ecotrons.com/products/sma...injection_kit/ half the cost of the entire bike
Old 07-06-2016, 07:38 PM   #34
'16 TT250   '16 TT250 is offline
Originally Posted by pcspecialist View Post
as with all carburated NOS setups, you have to run them rich.
No, the extra fuel comes on with the nitrous through it's own solenoid.
Old 07-06-2016, 11:01 PM   #35
MDStroup's Avatar
Your welcome. I have actually been looking supercharging a motorcycle for a long time. Mainly just as a project. Hopefully one day it will happen.
Old 07-07-2016, 01:13 AM   #36
JD, I'm really hoping you actually supercharge a bike; I'd geek right out.
Old 07-07-2016, 01:15 AM   #37
So the raspberryPI solution it is.... And some junk yard parts.... And duck tape.... Maybe a little JB weld....
Sincerely,
John Doe
Old 07-07-2016, 02:03 AM   #38
MDStroup's Avatar
Hey! Raspberry Pi's have been used to control robotic quadcopters with bananas! I think it maybe a little to advanced for this project. I think a ti30 would be perfect!
Old 07-07-2016, 02:10 AM   #39
Yea I can get the Chinese clones cheap maybe even Amazon, I wonder if a chip could do it.(9$ sbc there making....)
Sincerely,
John Doe
Old 07-07-2016, 03:49 AM   #40
MDStroup's Avatar
They still make the orangePi?
But in all seriousness, if you want to use the RaspberryPi as an ECU, i will look up a thread i bookmarked were a guy did turn a RaspberryPi into a ECU. It had all the links and instructions to do so.
Old 07-07-2016, 04:15 AM   #41
Why that surprises me I do not know.... Thanks for the lead and I will be looking for that myself, I would be surprised to see hack a day or someone like them didn't make a article on that.
Sincerely,
John Doe
Old 07-07-2016, 06:41 AM   #42
kohburn   kohburn is offline
kohburn's Avatar
that's only dry nitrous kits. a wet kit has jets to include fuel with the delivery.
- 2008 Kawasaki Versys
- 2016 CSC TT250
Old 07-07-2016, 09:15 AM   #43
Kdburtch   Kdburtch is offline
Dive in, Worst case scenario you have to buy a new Hawk motor which I believe are going for about $500. This bike with 20-25HP would be phenomenal.
Old 07-07-2016, 11:32 AM   #44
And I bet it would sound wicked.
Old 07-07-2016, 11:50 AM   #45
What if you had a second sets of jets supplied by a small electric pump that would not be to to hard to make and would more then likely work.... (If it handles Nos/supercharger well....) Why not throw in pre-oxidized race gas? Octane matched of course....
Most nitrous systems use a fuel jet and a solenoid to allow fuel through that jet, no need to reinvent the wheel to get a controllable fuel shot with the nos shot. Most systems use a fuel pump, but it can be done with a gravity feed with the right fuel jet.
The only stuff I know of that is oxidized is nitro fuel and wouldn't get along with the carb or motor. If you went that route you'd have to jet for it and be stuck running that high $ stuff all the time, it would also get much lower MPG adding to the cost.
Way back when I knew little about fuels and motors I decided to put some model airplane fuel (about 50% nitro) in my Honda MB5. Those little airplane motors make a lot of power for their size so it sounded like a great plan to kick up the little bike's power. I couldn't get it to start on the kicker but with a guy helping push I eventually got it to fire. It barely ran at first but as it warmed up it seemed to be getting happier and at one point it did have some serious power. I pulled back into my parking spot and it was idling around 3K and climbing so I turned it off, the idle continued climbing-WTF? So we're staring at it and I'm starting to freak out. I pulled the plug wire thinking the switch was bad, nothing. Pulled the choke hoping to flood it, just got stronger. Luckily it was only a 50cc motor so I held the rear brake and killed it by letting the clutch out. I drained that stuff out and never tried it again.
